frisco
Which of these drop-ins has the broadest (Surefire L4 Beam)?????
Thanks, frisco
Thanks, frisco
Hello,
@DanielG: Is there more Flood or more Beam?
Maybe in comparison to this dropin? https://www.candlepowerforums.com/posts/1922480&postcount=26
Got my BOG drop in. HOLY MOLEY! It's bright as all get out.
It is almost exactly the same beam as my Dereelight CL1H V3.0 now. I like the Dereelight because it's a 1X18650 light but I like the Surefire light too and now it's been running for about 1-1/2 hours without dimming that I can tell. I keep flashing the Dereelight into the 6P's beam to see if there is any difference.
I know, get 'em both. Well I did :thumbsup:
There's a 1/8-1/16" gap after the head's screwed back on, but I believe an O ring will fix that right up.
Thanks I just purchased the Deree light P60 Q5 dropin for $33(includes both SMO and OP relfectors). Will use it in my Z2:devil:
Newbie question....What does a deeper reflector mean to the user? I'll go out on a limb and guess it either means more spot and less spill or guessing again the other way around?I have an earlier Malkoff and the BOG Q5
The BOG is brighter by a fair margin. The Malkoff has a warmer tint if that is your preference.
The BOG has a deeper reflector then any of my other drop ins
Both are amazing
I take it you got the 1-SM2 model, yes?
I'm certainly thinking of going this route with a Z2... tell me how it works out
OK... SO I have a few questions for you experts.
I have a stock Surefire G2Z I'd like to convert to LED. I was planning to pre-order a BOG "super-premium" Q5 drop-in and a Borofloat or UCL lens for it...then, I got to thinking the the plastic body might not dissipate the heat from this module well enough. Would the P60L likely generate less heat? If so, would it be more preferable for this particular light?
Thanks in advance!
