naked2
I'd put a McClicky inside your SolarForce tailcap.
Dave:
Regarding my 3-mode XP-G R4 low voltage module that I use with 2x AA eneloops or energizer lithiums:
I've seen you mention that you set a pot on these drivers, and I see what appears to be a variable potentiometer on the back side of the driver. Is this adjustable to control current draw?
The draw on mine may be a bit more than solarforce tailcap switches are up to handling, as I have lost two. The module starts out drawing 3.8-4.0 amps on high (eneloops) depending on charge state, and stabilizes at 3.6a or so.
I'm very happy with the quality and output of this module, just wondering if its possible to adjust the draw a bit lower without affecting brightness much. Sorry if this isn't the correct place to ask, I sent a PM a couple of weeks ago but you must have missed it.
Thanks,
Mark
Hi Dave Wow 4 amps can this driver be used on a sst-50 ?Dave:
Thanks,
Mark
LOL you all have to be kidding
he is running 2XAA
He is running a AA driver and it is not going to run a SST50. The pot is on that driver only.
Dave
What tint are the XP-G neutrals you are offering?
Sorry about the laziness, it's probably mentioned somewhere in this thread... but it's getting late.
Do you have any of them available as bare emitters?
hi dave-
i asked about a 2 mode xp-g awhile back and iirc you said you didn't have any boards in stock- did you ever get any?
Hi Dave,
I could use some advice choosing a drop-in if you're up for it - I just can't choose!
I need something with plenty of throw, for a Solarforce L2. Tint isn't a major concern, and I'm happy to run it on CR123s or an 18650 - whichever voltage fits the 'best drop-in for the job'. Three levels would be ideal (low, med, high) - I have no use for strobe modes, but if the right module is single mode, then that's what I'll have - I'm not too picky!
Which option is going to give me a nice, tight hot-spot with plenty of throw?
thanks for any advice,
Regards,
Glenn.
Hi
The boards I have are not offering 2 mode at this time.
sorry
Dave
Big fan of your drop in's here. Looking forward to ordering directly from you once I can decide what to order.
Is there such a thing as a 9 volt driver avail for the Luminus SST-50 or 90 in order to run two 18650's or two 26650's in series?
thanks for your help in advance.
Kelly
thanks dave. i'll check back later.
