Received my MC Fabrications Bolt
and my Grafton pens this weekend! First impressions are that I love them both!
Grafton Pen:
Beautiful pen; subtle and elegant. No one will notice it's not a standard, boring pen unless they use it and then it screams expensive. Well-made, best threads I've seen on any pen (including my Maxmadco Bolt). Great click/knock although it does have plastic internals but I don't think it will be an issue. Comes with a Grafton refill which appears to be a rebranded Pilot G2. Comes with a spacer and different spring for using Parker refills. I had to trim the stock spring to make it work with the G2 refill as it was too stiff vs. the Grafton refill. Good weight but a bit slippery even with the grip lines due to the anodizing. Very cool that the top-most grip line is the split in the barrel; really hides it well. Nearly identical in diameter to a plastic Pilot G2, a bit thicker than a Zebra F-701.
MC Fabrications Bolt:
My model has the clip and the knurled grip. The clip is decent and is easily removed to bend it one way or the other for less or more grip when clipped in a pocket. The clip retaining screw can be screwed completely flush with the clip removed which is nice if you ever decide you don't want the clip installed. Shockingly smooth action on the bolt; he must've really improved his process since he first started making them (based on early reviews I saw). Such an amazingly pleasing click/thud you get when using the bolt. I like the sound and feel much more than my Maxmadco Bolt which sounded cheap to me and was difficult to actuate since the bolt was so flush to the barrel. Excellent grip due to the aggressive knurling, I love it! A bit thicker than the Grafton or a Zebra F-701 but not much so; very comfortable in my small hands. Only thing I don't adore about the pen is the brushed finish. I love brushed steel and titanium but aluminum is so lightly colored that it looks cheap to me bare. I think I may find a shop locally that can stonewash it for me which should be easily done since all of the parts are removable.
Grafton:
Grafton vs. Pilot G2:
MC Fabrications Bolt (w/ clip & knurled grip):
Comparison:
