Hi Phaserburn,
I apologize for the lack of updates. We've been busy trying to tighten up quality control. We are, in fact, making progress on the lens with the potential for a diffuser-type of setup.
LEDAdd1ct has been in touch with us, and I've filled him in on some details that I will share here:
1) we're working on some tinted lenses. red for sure, a frosted / clouded version, and potential for an amber and green variant.
2) we're also working on a flat black color scheme. our LED board manufacturer, SinkPad, has delivered some
very nice looking boards to us. i can't post any pictures, but in my opinion, they are much nicer looking than the glossy white versions.
Also, in general, we're just trying to make the 18650 more accessible. We've been bundling a charger and batteries with the R-PAL, and it's been met with moderate success.
I've also purchased a handful of lanterns to compare and learned a few things.
I haven't dug through the forums, but here are some relevant shots of the Coleman PuckLight with comments. The reason why I'm focusing on the PuckLight is because it is another lantern that uses an 18650. However, the battery is not easily removed, and must be charged in-circuit. The manual states that a full charge can take up to 5 hours (!!).
Here is the main lantern LED. It is the same one that the R-PAL uses, except we use 3 of them. You can see here that the PCB is very small, however it is mounted to a large metal reflector, which may help to dissipate heat. Each of our LED boards is about a 1/4 of an inch wide, and runs almost the entire length of the R-PAL.
Here's a shot of the main PCB. As you can see, it is pretty large, and not very dense. It also uses larger components. The R-PAL uses a much denser topography, smaller components, and our IC is a QFN package, not an SOIC. It is also completely separate, and is about an inch in diameter. Unfortunately, I cannot post any images of our PCB
You can also make out the 18650 battery behind the PCB. It uses some soldered-on tabs to connect to the PCB. Coleman claims that you can replace the battery -and you can, if you want to outfit it with the tabs. The instructions include directions on how to disassemble the lantern in order to properly dispose of the battery.
And this last shot is mostly for fun. We were featured in Men's Journal somewhat recently, and they had asked for some high res pictures of the R-PAL in action. So.. I busted out my trusty magnetic Joby Gorillapod, put the R-PAL on the side of my car, and snapped this photo. Many people criticize the utility of the R-PAL relative to a flashlight. We keep trying to explain that we're not trying to replace a flashlight. We're just trying to make a useful product.
As you can see here, the un-diffused R-PAL does a pretty good job. If you were on the side of the road, the R-PAL would provide ample, hands free light and also high visibility for passing traffic. Of course, I'm biased.. but I'll let everyone draw their own conclusions.
Again, I apologize for the delayed responses. I do remember to check in every now and then though!
OH! And if I don't swing by before then.. I hope everyone has a Happy Thanksgiving!
