plywood flashlights
Norm
Retired Administrator
Australia
Very Steam Punk, all you need to do now is get to work with the varnish. :goodjob:
Norm
alpg88
here is a new plywood build, since i gave 3 out of 4 plywood lights away, i had to restock, lol
light was build from parts i already had. used xpe leds 5000k, carclo 26,5mm narrow lens. luxdrive 1A driver 1 mode, 4x 18650 tenergy 2600mah, and pcb with equalibrium function, charghing is done thruside contacts, which are depowered normaly, upon placing it into charging cradle, a magnet in it closes reed switch.
inside lens holders i put small triangles of GITD tape, (fire exit sign). when the light is off it makes lenses glow green.
Gauntlet3D
I have done quite a bit of wood working. You could use some veneer banding on the edges and it would look more finished. They sell it where it is iron on with a standard clothes iron. so cut your pieces, iron them on, let the cool, and sand them down to size. unless you like the rough look which is cool too. NICE JOB!
dparr
Mid Tennessee
This is a very COOL thread!!!
I love these. They are works of art to me.
I would love to have one setting on the coffee table.
Thank you for sharing your work.
alpg88
thanks, I never knew such veneer existed, I only know of rolls that you have to use glue with, i'll look for it for my next builds, but my idea was that you see the plys, my choice of plywood isn't the best, thou, now I see that, but I already got plenty of craft grade plywood, for next builds.
Ken_McE
It seems completely mad, and yet, I want, I want to touch one, to run my fingers lightly along the grain, to feel the fullness and the rich heft of the plies in my sweaty palms...
If you'll excuse me, I'll be in my bunk...
alpg88
here is another one, still trying to find the narrowest led\lens combo.
this one has 4 xpg2 38mm ledil iris 4*. lenses are made for xpg\e\c, not xpg2, (it has different angle and primary optics), so it might not be 4* in real world, the beam looks narrow in smoke, but how it will perform in real world idk yet, will test it soon.
so this one is bigger than previous one, imo too big, and on heavy side to 1,7kg. not as big and heavy as some halogen searchlights, however.
it uses hyperboost driver, set to 1,5A i tried 50k recomended pot, but its range is very limited, basicly only in the middle it drops from high to low. table in the driver datasheet shows resistor values, and it does not go above 20k, i'll try 20k pot later, when i get one.
uses 6 tenergy 18650 2600mah, 3s2p. wired to be charged with hobby balance charger, each cell is protected. i used mic 4 pin plug as charging plug, radio shack sells them for $5 each , male and female.
just as previos one, it uses gitd tape (fire exit sign) inside lens holders.
Norm
Australia
I love this thread, each new light is like a new instalment of your favourite serial.
Norm
alpg88
thanks, i'll think of few new instalments than...
argleargle
Please, sir? Can we have some more?
Great concept, great execution, it makes me want to do it too!
alpg88
added deep red triple, to the side, driven at 500ma.
