Raysbeam
Hello Armytek I'm wondering why my Prime A2 v3 says it can run 1 AA, 2 AA or 1 CR123?
Hi there!
Yes, driver supports such voltage range.
For example you can use body of Prime C1 with the head of Prime A1.
Armytek
Will the Partner tail switch work on my Prime Pro C2 ???
I have noticed IF. I turn light on. Loosen tail cap. Tighten tail cap. Light comes back on. Very tactical. If I loosen just to light off, I can thumb it like it has tail switch. Also works on my Wizard. This does not work on my Prime A1 Pro.
Ordered an A2 pro. Hope it works out. I wonder if the head twists off as betting a 1XCR123/1XAA body would work on it. Then again I don't see those for sale.
Bodies of the Primes will lego. Just mind the voltage on the head. I have Warm C2 and Cool A1. Allows me to shorten light a little , and change tints for my tasks. I have a C1 body and non pro tail cap on its way.
Tail cap will switch with my Wizard but I don't believe the head light bodies are made to come off.
I contacted AT here and they took care of it.
Just shipped my Prime C1 Pro to China for warranty replacement. Keeping my fingers crossed that the replacement is free of glitches.
...I've used it a few times when it's been -15C. It cuts out and is unable to sustain the two highest modes after being outside for more than 20 minutes….
I received my Prime C1 Pro a week ago. To enter a firefly level from Off State, I "press and hold" the switch until I see the LED come on in firefly, and then I immediately release the switch, at which point the flashlight jumps to one of the Main Levels. This is not normal, is it?
To successfully enter firefly from Off State, I have to lengthen the time I "press and hold" the switch. This requires precise timing on my part, which I cannot always accomplish.
Even with a fully charged battery? What battery are you using?
