When I did my mod, I just used a dab of Arctic Silver 5 between the base of the emitter and the heatsink. It was a really tight fit to get it back into the frame (I had tried to cut the black frame out but my snips were too big so I elected to just leave it. The damage I did to the plastic made it a tighter fit than it otherwise would have been though. I think that I had been able to do so the reflector probably would have fit vertically but he frame holds the LED firmly so I'm okay with it the way it is. I did not sand anything off the bottom of the reflector, but I had to lose a good couple of mm off the top of it to get it to fit back in there. The lens presses against it tightly so it's a good fit and doesn't move at all. I get even less of a spot than the beamshots that were posted.
I don't really have a white wall to use, so a gray one will have to do I'm afraid. Actually, in retrospect I could have used the front wall of the house but it's too cold to go back out there at the moment. So gray it is. Pics were taken at ISO200, 1/30th sec exposure at F2.8. Wall was about 6-8 feet away (I'm terrible with estimating distance, sorry).
First the Apex. Even though you can see something of a spot in the picture, it's rather less noticable in real world usage.
Now for comparison, my P3D Rebel on turbo at the same settings.
And finally, the business end of the light. You can see the black plastic of the reflector where I sanded it away. You'll also note that it's not perfectly centered. What can I say, it's hard to hand-hold that reflector against the dremel wheel to sand it down and get it perfectly straight.
The pics really don't do it justice, it really DOES put off a lot more light. I had ordered some of FastCar's diffuser material to go on the light to diffuse it but I'm not sure I'm going to really need it since it's so diffuse now. I'm really not sure why mine came out so much more diffuse than cbubus did. He also did a lot better job with the mod overall I have to say. But I was rather in something of a hurry and I'm happy with the results and that's what counts, right?
