lctorana
Soon, I'll try to make one with a more reasonable 50mm diameter...
Ra,
Any progress on the 50mm TR front?
Whoo, RA. Fancy optics, there. Nice mathness. Imagine a 3 thousand lumen torch with one of those suckers. Expensive, probably, but, meh.Hi Gunner12,
I must slightly correct you on something:
If you talk about 3% loss of light, it would mean 97% bulblumens are converted into torchlumens.. That is not the case:
The conventional shape of most reflectors causes a loss of bulblumens, which is much more than 3%.. more like 25-35%
The high reflectivity of the reflector in my mini-HID shurely contributes in a better bulblumens-torchlumens ratio, but the most important is the the fact that the high reflectivity preserves the surface brightness of the source. Better throw is the result of that.
As for most efficient reflectors: Few months ago, I made a glass-TIR reflector (Total Internal Reflection) for use with the Seoul SSC P4 emitter..
The theroretics behind it:
Shot at 2007-09-28
A 30mm diameter version I finished earlier:
TIR means 100% reflection inside the reflector (optical fact, law of light). That, with a collimating lens at the center, and high performance coatings, creates a whopping 95% total efficiency. And this indeed does mean converting 95% bulb-(or emitter-) lumens into torchlumens!
I already build a light with a glass-TIR 15.5mm diameter reflector:
When I have the time, I will post a thread on this light in the Custom/modified section of these forums..
Regards,
Ra.
Hi, thread necromancers. :wave:
Why aren't optics more geared towards spill? Not necessarily in general, but why aren't there some that can best reflectors of the size in an overall balanced beam?
Consider the well-known Maglight reflector, with a LED, focused to a point. It's not the prettiest beam (not the ugliest, either, though), but it's very useful, with a good point, and lots of very dim spill. A great walking beam.
Now, consider a TIR beam that made a ~5 degree cone, instead of that point, and also gave 90-110 degrees of even but dim spill. In usefulness, it would blow the 'normal' beam away, and not be so big as even the small reflectors that do it, on top of being able to offer a better quality wider spill, and that oh-so-cool die projection, when you get it fit just right.
Amen, Ra.
(ancient Egyptian joke)
Earlier in this thread, you mentioned looking into making a 50mm TIR.
(I tried to ask about that a few posts up, but couldn't spell "TIR"...)
I would love to buy a 50mm TIR, but can't find anything larger than 35mm for a single LED...
Bruce.
Hey Ra,
When I picture the TIR in my head, I always think it would be better with a reflector around it. Why doesn't anyone put a reflector around this?
Your diagram is very nice, it explained a few things about TIR by itself.
I'm surprised that you don't get more light loss just from passing through that much glass, I mean, we lose 2% going through a UCL, don't we? Your light must be passing through 8-10 times more glass before it exits the light.
You know, guys, there ARE flashlights out there with TIR'S on them.
What about polycarbonate? It can be made plenty clear enough. Is the coefficient of expansion better?
There seems to be a couple of facts with lights:
1. The light engines will get much more powerful
2. Battery technology will improve
So this leaves the reflector...
The amount that can be changed on reflectors is finite and there are only a few companies trying unique reflector designs.
:lolsign: I had to laugh, sorrythe Rebel looks like a waffle
A reflector can be desigened to produce just about any beam pattern imaginable. The fact is, most flashlight designers simply don't design their products with actual usability in mind.Why does it seem that most non-focusable flashlights have such a concentrated hotspot? I know the companies are probably aware of the ugly donut hole caused when the bulb/emitter is moved up or down relative to the reflector, so they just concentrate the beam to a single spot to avoid this. My question is: Why can't a reflector be designed to give a wider hotspot without any artifacts?
I haven't heard of incan being used with TIR, but incan can be used in a "projector" configuration, that is, an aspheric lens, along with an ellipsoidal reflector.sorry to bring up a month old thread but im wondering
would TIR also work with incans, as it works with LEDs?
or is the light emitted from the filament too scattered to design a proper optic for it
The TIR-optics used in flashlights by some brands, are acrylic based: More fragile, can easily be damaged, huge thermal expansion. But they are easy to make. (at $3-$6 each)
They have about 90% efficiency, which indeed is much better than conventional reflectors
Glass-based TIR-reflectors are much, much, much harder to make ! I don't know anyone or any brand that makes them.. Do you ??
Edit: Oh.. I forgot: The main reason people are not jumping onto this is the lack of many sizes: The acrylic optics are available in only a few small sizes.. Soon, I'll try to make one with a more reasonable 50mm diameter.. Another problem is: Being from massive material, larger diameters TIR's will be heavy!
Regards,
Ra.
