Retro reflective Max return lumens
bakerboy1958
USA
I have a neighbor whose spotlight shines on my building. The reason why is too complicated. Is there a retro reflector that will return a high lumen light?
  • PXL_20231120_224523990.mp4
    14.6 MB
yellow
Baden.at
Too far away,
Not enough light (coming to Your side)
If there is still communication, try to get some kind of "blocking" onto the upper part of the light; reducing/blocking the light part that is just "wasted". (= everything above horizontal level)
or else
Mount a mirror (instead of something "reflector").
The bigger, the "better",
very, very, very slightly focusing also
Monocrom
NYC
Mirror idea might not be a bad one.
Get a large, full-length dressing mirror.
Set it up in front of your window.
But "forget" to turn it around towards you.
Depending on how obnoxious your neighbors are, consider consulting with an attorney to see if there's a legal way you can put an end to their nonsense.
bakerboy1958
USA
Too far away,
or else
I was first thinking of using a parabolic mirror. But the focus would be much too short to be any good. So I should look for a mirror with a very long focus or a very very slight focus? Is the focus measured? Not knowing much about mirror physics I'm just guessing. Thanks for your help. Please respond to my last question if you would.
Thank you
yellow
Baden.at
Like Monocrom typed, normal flat mirror.
At that distance any visible focusing would probably be too much.
Maybe ... when the mirror is big enough, it can be mounted onto a flat (sturdy) back plate,
Glued in in the middle, then apply some kind of "raise" at the outside ends, like 1 mm thick tape, or so.
The mirror can be bent very slightly before the glass beaks, and 1 mm will - probably - make for that sliiiiiight focusing.
But a flat one might work almost the same and is easier to handle
bakerboy1958
USA
Thank you for the suggestion. I'm already looking for a 36-in round mirror. I will find mastic to glue center. And find 1 mm tape for the edge. I can test it on my own yard.
bakerboy1958
USA
No, this a-hole complained about something on my property that is not bothering him. He shines the light on it so he can complain. It's a storage shed that needs to be repaired. But it's 100 ft from his 25 ft backyard.
In the meantime he shines his porch light on the shed that's on my property to say he doesn't want to see it.
I planned on repairing the shed but not this year. Since he can't wait and the city is pushing me. I would be happy to repair it ahead of schedule. But I will not be harassed. Hence, the mirror reflecting back his light. And when I make my improvements he's not going to be happy with the graphics that will be displayed on the building. And they will be illuminated with solar lights.
I am Sicilian. And Sicily has its own flag. I also have a family crest. Both these items will be painted on the back of the shed.
Over 150 large very expensive houses went up next to me. They overpaid on badly built houses. But the people think they have a absolute say so in the neighborhood.
Sorry for the long explanation. I hope the mirror operates the way I expect it to. Thank you again for your time and suggestion. I will let you know if it does work.
Attached is the flag and the crest.
RWT1405
PA
I see
So you're just looking to "fight" with him
Best of luck to you
yellow
Baden.at
Pretty much what we all were/are thinking.
Sure, the mirror (mirrors?) :D can be "blamed", but the light will come from the other side, so ...
