ro.ma.
- Joined
- Dec 3, 2012
- Messages
- 208
SPERAS P4 was sent to me directly from SPERAS for review.
For technical details and to purchase:
After testing the SPERAS EST, I thank SPERAS for sending me the more powerful but still compact SPERAS P4 .
The new P4 is a flashlight suitable for many uses both indoors and especially outdoors such as for research, camping but also for hunting and for the police force.
SPERAS P4 uses 3 OSRAM P9 LEDs, with a maximum output of 4000 lumens and a maximum peak beam intensity of 20750cd for a maximum throw of 288 meters.
SPERAS P4 is sold with a 5000 mAh lithium battery in 21700 format and is rechargeable via the USB-C port with a maximum autonomy of 167 hours (ECO mode) and can be used as a power bank to charge various electronic devices via the connector OTG included in the sales package.
P4 has a side switch to access all available modes, with 5 light levels (besides Strobe and SOS).
SPERAS P4 has lock function to avoid unwanted operation and reverse polarity protection to protect against incorrect battery installation.
It has an IP68 waterproof rating (2 meters submersible) and has shock resistance up to 1.5 meters.
The above data has been measured in accordance with international flashlight testing standards ANSI/NEMA FL1 using a SPERAS 3.6V/5000mAh 21700 lithium battery under laboratory conditions.
Main features:
Specifications
Weight: 185g/6.52oz (measured with battery included)
Dimensions: 119mm(L), 40mm(head), 26.5mm(tube) /4.68"*1.57"*1.04"(inch)
Warranty
The product comes with a 5 year warranty. For any non-artificial damage, please contact SPERAS after-sales service. The warranty does not cover normal wear and tear, modifications, misuse, disintegration, neglect, accidents, improper maintenance or repairs performed by anyone other than an authorized dealer or SPERAS itself.
SPERAS P4 arrives in a light colored cardboard box with the classic writings showing the main characteristics that distinguish it. Inside the package we find, in addition to the SPERAS P4 flashlight with the 5000 mAh 21700 lithium battery inside, the USB-C charging cable, the holster, the lanyard, 2 spare O-rings, OTG connector, manual and warranty.
The holster is well made with non-elastic sides and a Velcro fastening. On the back there is a D-ring at the top and a double loop in the center, one of which has a button closure. Once inserted, SPERAS P4 remains very stable without strange movements.
SPERAS P4, like other SPERAS products tested, has good overall quality with an excellent level of construction. It is made of aluminum alloy with an anodized finish, military-grade hard black. The grip is perfect for my medium sized hand. P4 is 119mm long and weighs 185g with the battery inserted. The central body of the SPERAS P4 is not smooth but has a design with four vertical grooves and three in relief which provide a discreet grip when holding it in the hand.
The inscriptions located on the head are well made.
On the head of the SPERAS P4 we find a projector with three SMO reflectors with 3 well-centred OSRAM P9 LEDs. With these LEDs, SPERAS P4 reaches a maximum brightness of 4000 lumens and covers a distance of up to over 288 meters.
The Bezel of the SPERAS P4 is slightly crenulated and protruding. It protects the anti-reflection glass above the projector well.
On the side there is the USB-C format charging socket protected by a fairly thick rubber cap. After connecting the USB cable to an external power supply (such as a USB adapter or other USB charging devices) the charging process starts.
While charging, the power indicator in the center of the button lights up red while when the battery is fully charged, SPERAS P4 stops the charging process and the power indicator turns green.
According to the manual, the charging time for a 21700i Li-ion battery (5,000mAh) is approximately 3 hours (charging via a separately supplied 5V/2A adapter). In my tests it took me about 3h30min to fully recharge the supplied battery.
During recharging SPERAS P4 can be switched on in ECO mode.
Power bank function:
After inserting the OTG converter, it can reverse charge your various electronic devices such as a power bank.
On the opposite side, of the charging socket, is the only switch with which the P4 is equipped.
In the center of the rubber button is the notification LED which indicates the battery status.
When the flashlight is on, the LED indicator in the side switch will automatically monitor the power for 5 seconds. The power indicator will display one of the following:
Green: 100%-70%
Orange: 70%-30%
Red: 30%-10%
Flashing Red: 10%-1% (Red LED will keep flashing to remind you of the power if it runs out soon).
Regarding the contacts with the battery we find a fairly thick spring at the end of the negative and a double spring at the head of the positive.
SPERAS P4 supports protected and unprotected 21700 batteries from other manufacturers as well, which is a good thing to take into consideration. I have tried some 21700 format batteries like the Samsung INR21700-40T, Nitecore NL2150 and Imalent MRB-217P40S with no problems.
The supplied battery is a protected 5000 mAh lithium 21700.
At the tail of the P4 we find the cap, the only unscrewable part, which allows us to insert or remove the battery. On the surface of the cap we find a diamond-shaped knurling, to facilitate the unscrewing operation, and a slot to insert the supplied lanyard.
The square-shaped threads of the torch body arrive well lubricated. There is also an O-ring for sealing against water and dust. P4 is IP68 certified (2 meters submersible).
SPERAS P4 together with other torches.
From left: Batteria Speras 21700. Nitecore P20iX, SPERAS P4, Sofirn SD05 e Emisar D4S.
USER INTERFACE (UI)
The SPERAS P4 user interface is very simple and easy to remember. The flashlight has memory (on Low, Medium and High) and has only a switch arranged on the side, five brightness levels and two special modes, Strobe and SOS.
ECO: 15 lumens, 167h
LOW: 100 lumens, 35h
MEDIUM: 500 lumens, 8h
HIGH: 2000-600 lumens, 90sec-6h
TURBO: 4000-800 lumens, 90sec-5h
STROBE: 4000 lumens
SOS: 500 lumens
ON/OFF
One click on the side switch to turn on/off the light. The flashlight turns on at the memory brightness (Low/Medium/High mode can be memorized when the power is off, the others are not memorized).
Change the brightness level
When the flashlight is on, press and hold the side switch to automatically switch between low, medium and high mode (the mode changes every 0.5 seconds), and the mode will be chosen once you release the side switch.
ECO/Turbo/Strobe and SOS
In OFF state, long press 0.5S to enter ECO mode. Quickly double-click the button to enter Turbo mode and single-click to deactivate it. In any state triple click to enter strobe mode; triple click again to enter SOS mode, single click to return to the mode before strobe.
Lock/Unlock operations
BEAM and RUNTIME
The beam of the SPERAS P4 has a good depth to illuminate well at low and medium distances. I shot a bit in the woods in the countryside using the medium level with good lighting.
Using it at the highest levels (High and Turbo) the heat produced is felt in the hand when used without gloves.
The coloring of the beam is not too cold, given that it is also evident from the tests made with the OPPLE Light Master instrument.
The coloration is yellowish with a clean beam without rings or artifacts. The widely exploitable spill begins adjacent to the walk. By eye I have not noticed any particular PWM or flickering.
We see in the photo below the wall test together with the Nitecore P20iX.
The values in candela (lux/1 metre), found by me with a measurement at 3 meters, are, in the two highest levels, greater than those declared by SPERAS in its specifications.
With a thermal imaging camera you can see how heat is distributed on the SPERAS P4.
The test was done in Turbo mode (4000 lumens) after 1 minute and 10 minutes from switching on.
The Runtime were done in an internal environment with a temperature of about 18°C, using the supplied battery, a fully charged 21700 5000mAh.
I would like to point out that the values expressed by the graphs must be evaluated above all as a reference because they are made with means and conditions different from those used in the laboratory.
SPERAS P4 has temperature control to avoid overheating which can cause damage to the flashlight or injury to the user.
In the tests made with the LX1330B Luxmeter SPERAS P4 does not seem to have a real adjustment. In Turbo mode the brightness has a sudden drop, shortly after the minute, both without and with ventilation.
Turbo 4000 lumens.
High 2000 lumens
Medium 500 lumens
The first 10 minutes. Added the curve in Turbo Ventilated.
VIDEO Review.
SPERAS P4 Unboxing and Use
CONCLUSIONS:
SPERAS P4 is a well built flashlight with a light output of 4000 lumens in a compact body with excellent hand hold.
Good level management with the perfect user interface, as a reference.
The package is complete with Battery, Holster and Lanyard.
Among the features of the SPERAS P4, the possibility of using the torch as a power bank to recharge other electronic devices via the OTG connector stands out.
The possibility of using non-proprietary batteries to operate the P4 should also be taken into consideration.
In conclusion SPERAS P4 is a powerful and complete but simple to use torch, suitable in almost all situations where good lighting and autonomy are required. Recommended.
Thanks for reading the review.
SPERAS P4 4000lm 288m Type C Charge LED Searchlight
The SPERAS P4 is a high performance LED flashlight with 4000lm max output that utilizes 3pcs imported OSRAM LEDs. Users can switch between the 7 brightness settings. Powered by a 21700 Lithium 5000mAh battery, a maximum A runtime of 167H can be achieved. It’s an ideal flashlight for searching...
speraslight.com
SPERAS P4 4000LM USB-C Charging Flashlight
The SPERAS P4 is a powerful, rechargeable, side-switch LED flashlight 3pcs imported OSRAM LEDs. Powered by single 21700 lithium battery (5000mAh), it could reach to 4000lm and 288m. Users can switch between the 7 brightness settings under the humanized operation UI. With the compact size and...
sperasflashlight.com
Main features:
- 3 OSRAM P9 LEDs (max 4000lm with 288m beam distance), compact and powerful.
- Compatible 1 * 21700 5000mAh battery, provides long battery life for up to 167 hours in ECO mode.
- Type-C charging function: the flashlight can be quickly charged within 3 hours.
- Power bank function: the flashlight can be used as a power bank to charge various electronic devices.
- Easy to activate Turbo modes, great for search and rescue.
- Lock function to avoid unwanted operations.
- ITS temperature control system with real-time sensing to ensure stable output.
- Easy to use, one side switch to access all modes with one hand.
- Over-discharge protection, automatically scale up when the battery is low.
- Reverse polarity protection to protect against incorrect battery installation.
- High strength aerospace aluminum body, manufactured by CNC precision machining with premium Type III hard anodized anti-abrasive finish for extreme durability.
- IP68 waterproof
Specifications
Warranty
Green: 100%-70%
Orange: 70%-30%
Red: 30%-10%
USER INTERFACE (UI)
STROBE: 4000 lumens
SOS: 500 lumens
ON/OFF
- When the flashlight is off, press and hold the switch (about 2 seconds until the ECO turns off) to enter lockout mode. After locking, press the switch, the orange LED indicator flashes quickly for 2 seconds.
- In the locked state, quickly triple click the switch to unlock the flashlight (the main light flashes twice when locking and unlocking).
BEAM and RUNTIME
Turbo 4000 lumens.
High 2000 lumens
Medium 500 lumens
VIDEO Review.
CONCLUSIONS:
