InfidelCastro wrote: "I sure would like to, could you tell me an easy way to do this? I have a couple of multimeters. Want to be careful not to burn out the fuse."
To get the current draw of the River Rock 0.5w 2AA -
Unscrew the tailcap of the flashlight.
Set your multimeter to a range that can take at least 200mA**.
Place the negative probe on the negative end of the battery -
now touch the positive probe to the body tube end - make sure you make good contact.
The multimeter should be giving your the current draw reading.
These simple steps apply to almost any flashlight -
except ** the range chosen -
often Luxeon LED lights can and will draw 300 - 1,000mA (sometimes more for higher powered Luxeons) - so choose the range that is capable of handling those currents. If in any doubt start with the 10A scale - take the initial reading - the resolution may be too low to get enough significant digits if the reading is below about 100mA - once the initial rough reading is known - switch to the more appropriate scale/range if necessary, to get the better resolution.
Of course if you have an auto-ranging Digital MultiMeter - then you don't need to set the range - other than to make sure the current range can take the estimated current you're about to measure.
For the River Rock 0.5w 2AAA - this should be more than likely < 200mA - ie: in the range of about 60 to 120mA.
