g36pilot said:
This may be a contributing factor, but shouldn't be the primary cause as the new UN testing uses a pressure test.
[font=Arial, Helvetica, sans-serif]
New Testing and Transportation Requirements
The new UN regulatory scheme includes many of the same provisions first developed in the VATCP. It also requires that all lithium and lithium ion cells and batteries manufactured after January 1, 2003 pass the following UN Tests prior to being transported:
Test 1: Altitude Simulation - This test simulates air transport under low-pressure conditions......[/font]
http://www.batterypoweronline.com/july02Li-IonRegulations.htm
As I understand it, passing the tests has various levels, each has a criteria for passing.
38.3.4.1 Test 1: Altitude simulation
38.3.4.1.1 Purpose
38.3.4.1.2 Test procedure
Test cells and batteries shall be stored at a pressure of 11.6 kPa or less for at least six hours at ambient temperature (20 ± 5 °C).
38.3.4.1.3 Requirement
Cells and batteries meet this requirement if there is no mass loss, no leakage, no venting, no disassembly, no rupture and no fire and if the open circuit voltage of each test cell or battery after testing is not less than 90% of its voltage immediately prior to this procedure. The requirement relating to voltage is not applicable to test cells and batteries at fully discharged states.
Take the mass loss criteria:
ST/SG/AC.10/27/Add.2
page 4
where M1 is the mass before the test and M2 is the mass after the test. When mass loss does not exceed the values in table 1, it shall be considered as "no mass loss".
-my note: from the table below shown below there, a lithium battery may loose anywhere between 0.5% of it's mass to 0.1% of it's mass during testing, depending on it's size. Thus one could puncture the barrier, and as long as nothing happened during that test, that exceeds each required limit, the battery would pass.
The document for those interested:
http://www.unece.org/trans/doc/2000/ac10/ST-SG-AC10-27a2e.pdf
The testing does not consider multiple conditions at once, or what happens over a long period of time (weeks/months). They are just concerned about what happens at the time of transport. There are a few, that look at what happens over seven days, like the charge test.
Now from the regulations themselves:
188 Lithium cells and batteries offered for transport are not subject to other provisions of these Regulations if they meet the following:
(a) For a lithium metal or lithium alloy cell, the lithium content is not more than 1 g, and for a lithium-ion cell, the lithium-equivalent content is not more than 1.5 g;
(b) For a lithium metal or lithium alloy battery the aggregate lithium content is not more than 2 g, and for a lithium-ion battery, the aggregate lithium-equivalent content is not more than 8 g;
(c) Each cell or battery is of the type proved to meet the requirements of each test in the Manual of Tests and Criteria, Part III, sub-section 38.3;
so on and excetra....
Notice how there are specific provisions if the cells cannot meet the above criteria, and how the pallet or shipping container must be then marked and treated for transport. As I see it, I'm seeing more and more lithium cells labeled as Dangerous, since they do not meet the UN criteria...
Reference:
http://www.unece.org/trans/danger/publi/unrec/rev14/English/03E_Part3.pdf
So, the implied idea that all Lithium cells meet the UN testing criteria, isn't so. It is just if they don't meet them, then you see the special Danger markings, and handling requirements, such that they fall under the Dangerous Goods transport requirements.
If they can meet all the tests and requirements, then they don't need to be treated as Dangerous Goods for transport purposes.
Someone earlier said the LAX incident that generated all the hub-bub on battery transport was due to alkaline cells. Not so:
"Lithium Battery Incident at Los Angeles International Airport
While RSPA was preparing its June 21, 2001 rule, an incident
occurred at the Los Angeles International Airport involving a
shipment of two pallets of small, consumer-size primary lithium
batteries that raised serious concerns at RSPA and the National
Transportation Safety Board regarding the exception then applicable
to lithium and lithium ion batteries. The pallets, containing 120,000
primary lithium batteries, caught fire and burned after being
mishandled and damaged by cargo handling personnel. At the time,
these batteries were excepted from regulation under the HMR and
ICAO Technical Instructions"
As for UL testing, if you look carefully, there are various levels for each test criteria. From memory, if I don't have them mixed up, a battery that passes to class 4 is allowed to vent, and flame, and it is considered to pass UL tesing class 4. It was something like Class 1, that showed no vent/smoke/flame/rupture/etc.
Often, the devil is in the details.
As far as some of the dangers of Lithium cells, here is another good presentation:
http://www.molalla.net/~leeper/lithexpl.pdf
Lithium Cells could be used in aircraft equipment though. Cells that meet the FAA requirements will each be marked on the body accordingly. These special cells fall under TSO-C179, and I'm not sure if this TSO has been officially approved or not.
http://www.faa.gov/aircraft/draft_docs/media/DRichTSO-C179.pdf
One should note specifically, some of the special provisions of things like shipping these cells, such as is found on the Energizer 123 cell datasheet:
Shipping: For complete details, please reference:
Global: Special Provision A45 of the International Air Transport Association Dangerous Goods Regulations
United States: 49 CFR 173.185
g36pilot Please notice the
Dangerous Goods provision, which would mean that they were not able to meet the criteria for not being classified as dangerous goods....and fall under special provision A45...
