Should I mod my Surefire 6P or buy a new flashlight?
lightbalb
Hello guys,
I'm wanting to have an LED light that will have good performance and be rechargeable. It's main use will be urban exploration, and hiking at night. So maybe around ~4 hours of use?
I've got a surefire 6P that I barely use because of the batteries being too expensive. It still has the original incandescent light in it.
Is it possible to easily and cheaply mod my old 6P to do these things? Or am I better off just buying a new light at this point? I'd like to not have to waste any money if possible, and the 6P has an awesome body that I really like.
Any suggestions guys?
Thanks!
scout24
Penn's Woods
Hello, and welcome. If you go to the Incandescent Flashlight subforum a few below where you are now, there is a 19 page thread titled "Why is the Surefire 6P so good" that reaches back about 10 years. Plenty of food for thought. Personally? Keep it, buy some 16650 cells, and a Malkoff M61L dropin module in your preferred tint, and enjoy. Not the cheapest, but probably one of the best choices. Happy reading!
vadimax
Vilnius, Lithuania
My option is Sportac Nichia Triple P60. Beautiful tint and useful flood beam with some throw:
If your light has a standard battery tube you should use a 16650 cell for rechargeable power.
bykfixer
Dust in the Wind
X2 on the 16650 cell and Malkoff low drop in.
You'll need a charger too and a Nitecore D2 (2 bay) or D4 (4 bay) charger will give you lots of safe battery charging options at a good price.
Malkoff has N for neutral (not white, not yellow but a nice tint that's easy on the eyes); W for warm (similar to your light bulb tint) or a standard white. The L series gives you a very noticable increase in brightness while providing 5 hours of steady output with a nice long period of dimming so you should get the 4 hour excursion in with a charged cell. Slip a 2nd cell in your carry bag and you'd be good to go if things get hairy.
peter yetman
North Norfolk UK
The 6P is a nice solid light. If anything goes wrong with it, it's easily fixed.
Use the 16650 cell, but keep a couple of primaries for emergencies.
The Malkoff drop ins are solid and reliable, you won't regret getting one.
Illumn.com also stock Malkoff drop ins, the stocks are low at the mo but they'll be back. They specialise in Nichia 219 drop ins which are very gentle on your eyes and show colours very well. Sorry Mike.
P
ven
Manchester UK
Another keep it and upgrade the engine here as well. 16650 cells offer 2500mah , drop in wise its almost endless................
gsr
Utah
Keep it, but go with a Malkoff M361 drop in, and upgrade your tail cap to a McClicky. You'll get three levels of light that you can rapidly access. Your run times on the lower levels will give you more than enough run time for all night use.
berryns
+1
Except I would get the M61NLL or WLL.
Timothybil
The great state of Misery (Missouri)
One note: If you are going to carry extra cells, make sure that they are in a container of some sort that will guarantee that they will not short out against anything. One thing you never want to see is a lithium primary or Li-Ion cell self destructing due to a short. Many Li-Ion cells have protection circuits that are designed to cut off the output if the cell is shorted, but it takes some small amount of time for that to kick in, and one really doesn't want to place all their trust in it operating properly in a timely manner. It is better to make sure the situation never arises.
Timothybil
While I agree that Malkoff Devices are the gold standard, they are a little to expensive for my tastes and usage. I have a CUXM/CUXP drop in from Mountain Electronics that I really like. I chose the Nichia 219 emitter for the high CRI, and the standard three mode levels. One can also select several Cree options for the emitter/reflector, and any of several mode sets as well. One can't beat the price, and it works very will with the single 16650 cell in my 6P.
Note: You CAN NOT use it with two CR123 or RCR123 cells. The over voltage will let the magic blue smoke out, and we all know that once that smoke is gone the device in question will never work again.
Crazyeddiethefirst
Southern California
Another vote for keep it, go with a drop in and a McClicky. You can continue to upgrade the 6p every time something newer or better comes along for infinity. What I have found(and I have way more flashlights than I can ever justify) is that I do not need thousands of lumens for everyday stuff. In fact, I don't need several hundred lumens(my Caveat is except when I do search & rescue, then high lumens are needed). Almost everything I do actually requires nothing more than 100 lumens. My point being that the 6P is an excellent host and can be outfitted with batteries and drop ins to suite every need. Because they are affordable I have several, each set up to a different purpose...I love the Malkoff drop-ins, but also have the Sportrac Triple and a few custom made ones. I keep my Silver 6P in the original configuration knowing it can sit for 10 years and work as well as day 1(I love incandescent for some things), and I know what I am grabbing if I need it in a hurry. Please let us know what you decide, and after a couple months let us know how it is working out for you...
ChrisGarrett
Miami, Florida
I dumped $40 for a 3 mode Redilast XM-L2 U2 P60 running at 1.5A on high and a pair of Redilast 17670 protected cells that fit perfectly.
That's all I'm going to do with mine, for now.
Good luck, Chris
lightbalb
Oh don't worry guys, I had no plans of ever getting rid of this thing. I just recently heard that this model has been discontinued.
I'm exactly as invested in flashlights as you guys are, and I'm very inexperienced when it comes to these things. The reason I got the 6P was because I just like to buy quality products. If only I known the batteries were that expensive.. :D
Nevertheless, I was saddened to that they aren't making the 6P anymore.
I will definitely let you guys know what I choose, but so far I'm kinda overwhelmed as to which options I should take. I believe the battery is obvious. I will go with a 16650 rechargeable or two. I won't be going for the larger sized one (18xxx something?) because I don't want to bore my flashlight. Also, would I be okay just buying like a 15 dollar charger and any battery off Amazon?? Or are there brands out there that are noticeably better and worth buying? Whats the best bang for the buck?
Especially when it is no longer on the market... I think if I ever wanted one of those, I would just opt for a cheap solarpower L2? If I'm not mistaken.
So that leaves the drop in light, I'd like to go for a LED because I've heard they are superior. However I'm not sure which drop in does what really.. I hear malkoff is pretty much the best product in terms of quality, but I can't really tell the difference between them or whether its worth getting the other mentioned brands.
lightfooted
Keeppower 16650s are what I use and are a newer, higher capacity battery. I recommend just finding a Nitecore charger, the Intellicharger i2 is good and simple to use. It can also charge NiMh batteries as well.
I have a Mountain electronics and Solarforce in each of my Surefires and they both work great. At Mountain Electronics they have a pretty diverse selection of possibilities from the LED to the controller board. You can even custom order the driver to do what you want within the scope of the platform. Be careful though, you may soon find that 6P mods are a deeper rabbit hole than you first imagined.
