Skilhunt H03 - elasticated headband alternative
Glow808
EMEA
Hi
I've been using the H03 for the last few weeks with just the round the head band (without the over the top headband bit), great headlight with good flood beam for the small and lightweight size
:thumbsup:.
But I'm not really liking the black rubber holder for a couple of reasons:
1. Its bulky with the top section for the over the top band, which I don't use
2. It leaves a more pronounced mark on my head after only a few minutes use
Have looked at a couple of alternatives:
Skilhunt's HB1, their elasticated headband for flashlight, which could be used for my H03, but don't know if the elasticated bit holding the headlamp would be wide enough to hold it in place securely without too much movement and the issue of leaving a mark on my head as mentioned above.
https://www.skilhunt.com/product-detail/hb-01-headband/
Nite Ize headband, nylon non elasticated, circumference adjustable by hook and loop, the elasticated loop into which the headlight slides into is sewn onto the outside, hence no protruding parts on the inside to leave marks on the head. Not sure how well it will sit on the head without slipping due to non elasticated.
http://www.niteize.com/product/Headband.asp
Are there any other alternatives out there I have missed?
Nev
Banned
I use a zebra light h600 band , I ordered a spare with the light.
