<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:</font><HR>Originally posted by Spudgunr:
I seem to be having trouble when I solder. Usually, it is with my PR bases and I am trying to hook a negative wire to the outside. The Solder never seems to stick to the outside. Is this because the outside is too smooth, or because I don't know what I am doing, or what? Also, when I run my wire out the insulator in the bottom, and try to put a blob of solder on it, the solder never seems to stick their either. Most of the time, when I pull the soldering iron away, it just sticks to the soldering iron instead. Any tips to change my luck? If you have any related, or non-related tips, please help me, I would love it.
Spud<HR></BLOCKQUOTE>
-Spud,
You didn't say whether you are using any flux or not..?
Also, are you preparing/cleaning the surface properly?
How about "tinning" your iron?
-All pretty basic stuff, but not knowing how much experience you have, -just a few suggestions:
1. surface should be cleaned thoroughly, and abraded (roughened up) a little.(emery papr/file)?
2. flux applied to surface
3. iron adequately heated up and it's tip..-wire brushed/cleaned.
4. surface adequately heated.
5. decent solder, (the kind I like is Kester 2% silver solder)because it goes on smooth as a baby's butt, sticks super well at low temps, and stays nice and shiny.
Hope that helps
