D
**DONOTDELETE**
Guest
Phantomas2002:
Thanks for the tip ... glueing a PCB layout onto the copper and then cutting it with a Dremel tool sounds like a workable way to go without etching.
I think the Dremel bit you are referring to is a 5mm burr. I've seen them with round and pointed tips ... the cutting part has file-like edges on it?
For those of us without AutoCad, any decent vector-based drawing program that provides accurate measurements will work (Corel Draw, Adobe Illustrator, etc.). Photo or painting software (Corel PhotoPaint, Adobe PhotoShop, PaintShop Pro, etc.) will not work. The ability to scale the size AND retain high resolution is critical. Hand drawing will work if you are that talented (I'm not).
I have yet to try doing an image transfer onto copper from a laser-printed page, but if it works as well on copper as it does on some other materials, I'll detail the process here. It would mean being able to cut the traces closer together, with better accuracy (the thickness of paper on top of the copper will cause distortion).
I'd love to have some workable circuits in four weeks! Hopefully, all the parts will be here by then.
Thanks again ... you are a fount of information.
Mark
Mark
