This may belong on this thread, or possibly not. Feel free to holler if not...
I had previously tested my Cree L1 for 5 minute periods with a SF cell. Tonight I tested it for 55 minutes on high continuously while running with the dogs. The results weren't quite what I expected, considering this is supposed to be regulated - but it could be a battery issue. Please inform me if you can!
Being the cheap and possibly foolish ******* that I am, I used a Battery Station lithium cell for this (starting voltage 3.6V) instead of a SF. That may be significant. Sorry for the lack of brightness readings - this started out as a simple "flicker or no flicker" test - I
am a scientist after all!
(1) I was holding the light only by a lanyard attached to the clip and to the front of the light to avoid thermal issues of any sort, helpful or otherwise. I frequently checked warmth by touching the light with my lips, which are more sensitive to temperature than hands. The head section
never became warmer. The battery section warmed noticeably, but never became remotely "hot". For the record, the 5 minute tests with SF batteries had the exact same thermal results.
Question: Is this a sign of very good heat dissipation by SF's engineers, drawing heat away from critical components? Certainly a very different pattern that what I've experienced with any other light. But how on earth could this square with other posters' observations like "Temperature head (max): 45 C / 113 F" and "When I shut it off, it was hot, but still possible to hold" ?? Does this mean there is something wrong with mine?
(2) During the run, the light dimmed
gradually. No flickering at any point, and no step-down. I briefly tested the low beam at intervals and it appeared to be dimming gradually as well. By 29 minutes, high was getting quite dim and low was barely usable even close up. At end of test, side by side center beam comparison at a distant target showed Inova T3 was at least 4x brighter, although pre-test the Cree L1 was significantly brighter. My Luxeon L-1 on low was far brighter than the Cree on low.
Question: Although the regulation may be less than perfect on both high and low (see
www.candlepowerforums.com/vb/showpost.php?p=2076061&postcount=1If), should this light be dimming continuously from around 20 minutes into a test, on
both high and low settings, if it is regulated at all? Or is this just a battery issue? Should I consider returning the light or testing further?
(3) Subjectively comparing in dark room, the Cree L1 on high with the used BS cell appeared only a little brighter than the low setting with either a new SF or BS cell. End voltage was 1.73V (!) After 5 minutes rest 2.66V, after 32 min 2.81 and the light was now just a little dimmer on high than the T3.
Question: Is this entirely a battery issue? Would the results have been different if I used one of my Surefire cells?
Final Question: Was this light ever intended to be used for protracted periods on high? If not, should Surefire have stated this? (For the record, I really like almost everything about this light, at least the one I have.)
Sorry for the length, and any insight is gratefully welcomed.
- Bill
