jon_slider
- Joined
- Mar 31, 2015
- Messages
- 5,181
Testing the Low Voltage warnings on a Novatac 120T
ran down an Olight protected 16340 ICR battery
at 3.1v the Novatac stepped down to 30 lumens,
less than a minute later it switched down to 18 lumens
about a minute later it stepped down to 8.2 lumens. Battery was at 3.02v
less than a minute later it stepped down to 2.9 lumens
less than a minute later it stepped down to 1.9 lumens, it stayed at that level for about 10 minutes
10 minutes later the light stepped down to 0.4 lumens at that point the battery was at 2.99v
less than 1 minute later, the light stepped down to 0.2 lumens
less than 1 minute later, the light began to blink continuously, at 0.1 lumens
after about 27 minutes of blinking, it started to flicker on every blink, I let it keep running, Im waiting for the light to turn off so I can know at what level HDS first shuts off a depleted LiIon.
After about 3 more minutes, the flickering changed to slow flashing on some blinks and fast flashing on other blinks.. Clearly the HDS has multiple blinkies for low battery warnings.
After 42 minutes of blinking at 0.1 lumens, I turned the light off to check battery voltage, it read 2.91v
When I turned it back on, it came on at 5 lumens. a double click gave 24 lumens, and about 30 seconds later the light turned off. The battery was at 0 volts, because the battery Overdischarge protection circuit took effect.
So I do not know at what voltage the HDS Low Battery circuit might have shut the light off completely, but I do know that after removing and reinserting the battery, the light was willing to drain the cell to the level of the Battery Overdischarge Protection Circuit, which is 2.5v
btw, even though I removed and reinstalled the depleted battery to test voltage, multiple times, I did not do a battery reset, and the light continued to operate normally for LiIon, by stepping down to a very dim level. fwiw, on my Novatac, battery resets are not automatic the way they are with the latest HDS. You should not remove and reinstall a depleted LiIon with the current firmware, as the light might confuse it with a Primary cell, and attempt to drain it below 2v, unless you use a battery with a built in Overdischarge Protection circuit.
Bottom line, HDS has great Low Voltage warnings, but does not have complete Overdischarge Protection. It WILL overdischarge a LiIon if you turn the light off during the 0.1 lumen blinking. It turns on @ 5 lumens, this suprised me, I expected it to only come on at the 0.1 lumen level the blinkies were at.
The Low Voltage warning feature of an HDS is documented in the latest 2.18 firmware version of the manual as Low Voltage Indication, there is no mention of Overdischarge Protection in the Manual.
Bottom line, HDS has NO Overdischarge Protection, nor does it claim to. It Can Overdischarge, IF the operator turns the light off, and then back on after the Low Voltage Warning blinkies. Despite the commonly held belief, HDS does not have Overdischarge protection, it has Low Voltage stepdowns and blinky warnings.
