HKJ
So since it shows the charge delivered to the cells - i wonder if there was any way I can use this charger to weed out dodgy batteries which do not provide the advertised mAh.
Yes, as long as you can discharge the batteries in a controlled way, i.e. you need something that uses one battery and automatic turn off when the battery is empty.
Then you can charge the batteries and compare the mAh.
I understand that having one poor battery in a group can significantly degrade performance overall.
Correct, when you uses batteries in series.
On car batteries (Lead-Acid) I used to run a drop test where a known load is applied and if the voltage drops below 9V then the battery is not good enough for use.
Is there such a test on these Li-Ion batteries?
You can something equivalent on LiIon with a voltmeter and a resistor (1ohm power resistor is fine). The actual drop will depend on the battery, but all batteries used together must have about the same drop.
Checking tailcap current on a single cell high power flashlight can also be used, all batteries must again show about the same value.
