Test/review of LiitoKala 26700 4000mAh Lii-40E (Orange)
HKJ
Copenhagen, Denmark
[size=+3]LiitoKala 26700 4000mAh Lii-40E (Orange)[/size]
Official specifications:
  • Battery Type: Rechargeable Lifepo4
  • Nominal Capacity: 4000mAh , Real
  • Nominal Voltage: 3.2v 3.3v
  • Battery Dimension: 26.5x71mm(±0.02mm)
  • Battery Weight: About 93g
  • Internal Resistance: less than 20 mohms
  • Cycle life: More than 2000 times, DOD at 80%
  • Input Charging Voltage: 3.65v/cell
  • Input Charging Current: 2A
  • Continuous Discharging Current: 3C
  • Max Current Discharge: 5C
  • Discharge cut-off Voltage: 2.50v/cell
  • Charging Temperature: 0°C ~ 45°C
  • Discharging temperature: -20°C ~ 60°C
  • Storage temperature: -20°C ~ 45°C
A LiFePO4 in 26650 size with fairly good capacity.
The two cells matches very nicely and can deliver the rated 3C or 12A.
Discharge-LiitoKala%2026700%204000mAh%20Lii-40E%20%28Orange%29a-pulse-1.0%2010%2010-IR.png
[size=+3]Conclusion[/size]
This is a good LiFePO4 battery and as usual for this type it has very stable output voltage and less energy contents than the more common LiIon types, but longer life.
[size=+3]Notes and links[/size]
The batteries was supplied by a reader for review.
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Graphical comparison to 18650 and other batteries
Table with all tested LiIon batteries
raggie33
*the raggedier*
im so grateful for all your work and reviews ive spent much time on your webpage
abhi555
Idaho
Nice, 30 A must be brutal for any cells.
can lifepo4 charged quickly if charger can deliver more than 1A constant current (as per tests), any damage it can cause in this case?
