Test/Review of Sanyo UR18650ZY 2600mAh (Red)
HKJ
Copenhagen, Denmark
[size=+3]Sanyo UR18650ZY 2600mAh (Red)[/size]
Official specifications:
  • Rated capacity min.: 2450mAh
  • Capacity: Min. 2500mAh, Typ. 2600mAh
  • Nominal voltage: 3.7V
  • Charging: CC-CV, Std. 1750mA, 4.20V, 3.0 hrs.
  • Weight Max.: 48.0g
  • Temperature: Charge: 0 to +45°C, Discharge -20 to +60°C, Storage: -20 to +50°C
This cell is some years old (Datasheet from 2012) and capacity and current is not very impressive by todays standard,
The discharge curve looks good, the two cells tracks nicely and capacity is fairly constant with load.
[size=+3]Conclusion[/size]
Being old style non-IMR 2600mAh cells they do have a fairly high voltage during discharge, in some applications this is an advantage compared to the newer 2900+mAh cells (This advantage is also shared with the 4.3(5) volt cells).
It is a very good cell.
[size=+3]Notes and links[/size]
How is the test done and how to read the charts
How is a protected LiIon battery constructed
More about button top and flat top batteries
Compare to 18650 and other batteries
ChrisGarrett
Miami, Florida
I just ordered the Ruinovo 4x18650 power bank that you reviewed (FastTech) and it's coming with four of these Sanyo 2600s. I already use three here and actually keep one in a seldom used ZL SC-600.
They're quality cells, if not a bit dated, but they should work well in my power bank.
Thanks again, Chris
Zorzi
Thanks for this review, HKJ! Regarding it not being IMR (Lithium-Manganese) Li-Ion, so does that mean it is ICR (Lithium-Cobalt) Li-Ion?
