peter yetman
6P size is really too big for clipped pocket carry....
BIGGER POCKETS!
I get what you are saying about the high lumens. I guess I missed that. I have a surefire E2O with momentary switch. I have the lumens factory single mode led drop in that runs around 300 lumens. It is perfect. I ended up putting the drop in in my original e2d and e2e also. I can run them on primaries or on 2 16340s. I then put one in my old incandescent TL2. I guess that's the answer. You have to make one yourself.
It would help if OP described exactly what tactical means to him. Lumens, clickies etc?
Does it require a forward clicky or a Surefire silent type push on release off or will an ordinary clicky be OK? What lumen range? I get that you want single mode,that's easy but there are other criteria. Do you want flood, throw, what? Does tint matter? The LX2 sounds great to me as a tactical option but of course it is 2 modes.For use in conjunction with a handgun. The proper way. Quick flash then move then flash again. On most lights, that will put you into some stupid low mode or strobe.
800 lumens? Really.
Ok all you try this. Wake up in the middle of the night and the house is dark. Go out into your white walled hallway, and hit a flashlight with 800-1200 lumens on high, and blind yourself........not cool.
Like I said, the true tactical flashlights are dead.
There is a low mode if needed that is safely located and not easily accidentally activated. Plus, I have done what you are saying with more lumens, that were more focused, and I was not blinded. Sure it was a bit harsh of my eyes but, not much worse then flicking the AC light on and I still was more then able to focus and maintain my situational awareness. Keep in mind too that the Tactician uses an extremely floody beam(MV) meaning it doesn't seem as bright as a more focused light and causes less glare and reflection.
You do know the Tactician is designed buy a highly experienced firearms tactics instructor and ex SWAT team leader right? His company even specializes in low light tactics. The Tactician has also been praised by many other highly experienced professionals and dimed the best improvised firearm flashlight of all time.
So, while your definition of "true tactical flashlights" may be different, many people that very likely dwarf your experience and training ten fold don't agree.
That is what it is looking like. Find and old Surfire E series and add a LED engine that isn't crazy bright.
Well, one of the best instructors out there agrees with me that the newer lights are too much, and ruin your night vision. Of course, most of these famous tactical teachers do it wrong, too. They turn the light on and leave it on, hey, just like in the movies and on TV!!!:ironic: But if you do it right, flash and move, you are blasted with the backlash of 800+ lumens and then in the dark again, blind. That is why Surefire is coming out with Intellibeam....
Which instructor is that? And, have you actually taken some training or just watched some Youtube videos?
Yes, they can be too much for certain scenarios but, generally too much is much better then not enough. And, more is better at disorienting or blinding an assailant which can be very helpful in many scenarios. You also have to keep in mind that beam profile is a big consideration too. A tightly focused beam can seam more bright and cause more glare for the user then a floody beam that is much more bright. Colour temperature has an effect on this too.
There isn't necessarily a right or wrong way to do it. It is about using the right tactics for the situation. And, the right tool as well. You also have too keep in mind that tactics are always evolving and being refined so, just because someone might have once taught you one way of doing things doesn't mean that that hasnt been improved on or even made obsolete.
The Intellibeam has been out for a while and it was actually designed more for general use lights not tactical ones. With a tactical light you want to always know what you are getting when you turn it on.
With the intellibeam, it is my understanding that it always come on full blast, but the sensor dims it according to surroundings. And yes, I have taken low light firearms training. I have simualted the training with a SureFire G2Z and P61[120 lm], E2E with LF drop in[250 lm] and with a 500 lm EB2 on the house with white walls. The 500 lm EB@ destroyed the night vision. Way to much back scatter.
