That's awesome. Yes please do that! Thanks a bunch!!!
4 Free 18650 for Cyber Monday. Cheers!
How do you like your R90C ?
The rot66(vn) and d40s(vn) are such great lights, my go to for daily use.
I like it alot.. this light doesnt failed on me. I must tell you some of the leds are not prefectly centered.. it doesnt effect the beam.. it looks great on the white wall.. i measured 16000 lumen wih the tube.. i have no doubt this light is around 18000-19000 lumen if someone measure with the ansi lumen tube..
Steve, you'll love that MK34vn. It's as much a piece of art as it is a flashlight. And, it feels great in the hand. It makes a smooth wall of light, I think no matter which LED. Vinh's UI is the icing on the cake, because Manker's is confusing.
One thing to consider with the factory driver vs vinh's driver is regulation. I'm not sure is VNX has flat regulation in lower ouptuts or not. The fireflies driver uses 13 regulation chips on lower outputs (flat regulation on outputs up to 1400 lumens on sst20 version and higher on xpl hi version), and fet (direct drive) for higher outputs.
I've had both the lh351d and sst20 versions of the rot66. For less than half the cost, I'd definitely get the sst20. SST20 outperforms the lh351d in color rendering, and it throws better with a more defined hotspot. lh351d is just a wall of light. lh351d does make for a little more output on turbo though.
Vinh also has small hands, so keep that in mind. I have normal-slightly larger than normal sized hands, and I think the ROT66 feels tiny.
Having said all that though, the responsiveness of VNX and its many customizable mode settings are also really good.
I think i measured around 7500-8000 lumen turn on for the mk34vn cw... i also run the turbo for couple minutes and it gets super hot.. the light doesnt step down and the driver vnx2 survives..
I like the switch on the mk34vn.. more responsive..
rot66 have all the cool stuff like aux led, ramping, low battery indiciator.. aux led turn off and red led appear when the battery reach 3.29v..
