Some time ago, the issue of Mercury startup time had gotten the best of me and I'd decided to make live comparisons to the best of the Xenons.
The issues that had prevented me from going with Xenon in the past are luminous efficiency and the size and weight of the power supply making the system completely unportable while also requiring only 240V AC input. With certain Xenon lamps however, I can design a power supply from the ground up that operates extremely efficient on DC input with a total system weight of under 11 lbs for 1600W as opposed to say around 100 lbs.
Separating the AC to DC component in the power supply design and eliminating the massive transformers allows the power supply to be incredibly smaller and lighter for portable DC operation, with acceptible DC input from 10-80VDC. For running the power supply off 110VAC, 12VDC converters are available for cheap.
I've also devised a method to greatly extend the usable output range so that much lower wattage lamps could be used. Traditional power supplies have a narrow output range because lower watt Xenons are damaged by the startup phase of power supplies designed for higher watt lamps.
My first live comparison is that of the hot spots of the Mercury lamp next to the 1600W Xenon through a double layer of #10 welding shield plus a single layer #5 welding shield, and I like the result. In the photo below, Mercury is on the left and 1600W Xenon is on the right. Although difficult to tell, the Xenon is measurably much brighter at the center of the hot spot, even though the Mercury has two significant advantages in the test. Firstly, the Mercury is a brand new lamp and the Xenon is near EOL. Secondly, Mercury is a "greener" output than Xenon's pure white, therefore the Xenon is more filtered by the green welding shields.
Double layer of #10 welding shield plus a single layer #5 welding shield..
Below are the lamps under #10 welding shield..
Below are the lamps half way through cool down..
Next, I have on order for testing my favorite Xenon on paper, the XStage 2000W. This lamp has 170,000 cd/cm^2 average luminance and can be driven continuously at over 2500W with 208,000 cd/cm^2. However, this lamp may or may not be suitable for the power supply design I have planned and I would have to perform an electrical test of the lamp's startup nature as well. I will receive this lamp for testing this week.
Finally, I also have on order the Ushio version of the famed and long gone XBO 500W/RC OFR with 260,000 cd/cm^2 average luminance. This is no longer in production by either company for quite some time. But for a price, Ushio is producing one for me with the option to order a run of them if all goes well. I ordered a month ago and it should arrive in a few weeks.
I'm excited to compare first hand all of the lamps that have always been at the top of my want list. I will post further comparisons as soon I receive the next two lamps.
