Thermal config in anduril
Manas
How do I interpret and adjust the thermal config and turbo runtime in this mode? Thank you
jon_slider
what worked for me is
get into thermal configuration mode, then:
1st calibrate the thermal sensor
2nd set the temperature at which thermal regulation kicks in, I use the lowest number
The Anduril Manual is here
The Anduril Flowchart is here
and here is a post you could reply to, if you need more help
https://www.candlepowerforums.com/v...ow-available&p=5317568&viewfull=1#post5317568
High powered pocket rockets like the FW3A get quite hot during operation. This is normal. Thermal regulation in the driver ramps down output to prevent the light from getting too hot.
In general, the light innards and battery can take a LOT of heat. The usual limiting factor is your hand, since the head should never become hot enough to cause burns.
