Tigerlight battery 3500 or 4000 mah
dano
East Bay, Cali.
If I remember correctly, the original Tigerlight battery pack consisted of A size batteries, 6 total. MAH was 2100MAH, or so at 6 volts. An odd size, not available in 3000 MAH. BUT an A sized cell is also known as a 17500 size cell in lithium batteries. Assuming you could build or find someone to build a two cell 17500 battery pack, it could power a Tigerlight, as two 17500's in series would give a bit over 6 volts under load, with a capacity of 3500MAH, or so, depending on the cells used.
