Not sure if this has been discussed before, but I've found that in the lights where I have problems fitting the carrier into the flashlight with these batteries, if you rotate the batteries to where the metal strip for the positive lead to the protection pcb is facing inward, the carrier fits into the light where it won't otherwise.
Hope this helps someone..
Cheers!
Cheers!
