fortean101,
I coined the term mule a while back because I needed a name for a light and I wanted that name to reflect the nature of the light. I perceive the mule as an animal that just does its work with no glamor. Nothing to brag about. Unlikely to be any contestant; what contest?
Guys,
You can get this as a High CRI Head only and I am willing to offer the head without LE for those interested. If you want the titanium mule head empty with no LE the price is $110 plus postage.
I didn't want to start this wave and confuse the issue with all of the possibilities. The price for a Mule that was host to a XP-G LED instead of the Nichia 119 would be the same.
I need to get around to editing the UV wave with the addition of this titanium mule head as well.
This titanium mule head has the same geometry as the previous aluminum version and some will note that it seems to have a short skirt when coupled with the battery pak. The O-ring is digested in the head but can still be viewed. This consideration was originally made for use with the SF L1 lights and other battery paks that had shorter penetration than typical or the standard.
The mule head has a lot of potential applications. The LE in a Makai can easily be removed with no concern to reflector alignment or O-ring positioning and screwed into a Mule head and then returned to the Makai. Obviously the thermal relief would not be the same!!
Guys,
