gofastman
So the TK75vnQ XHP70 SD DriverVNX2 is more of a floody type light, correctly? I usually like a mix of flood and throw, should I go for the TK75vnQ XML2 PDT + DriverVNX2 ?
How long do they both last on highest brightness overall? I'm about to go through all 6 pages again in case this was already answered.
On max output you will be limited by heat rather than battery life. You can run it until it becomes uncomfortable to hold. It also has a turbo timer you can program that will ramp the output down after a certain amount of time, it's set to 5 min by default.
