Ultra High CRI 95+, Smooth Full Spectrum LED Light Strip/Fixture of choice?
jross20
Georgia, USA
Hey guys, I just ordered a sweet new work bench and i want to set her up right with a high quality bench light. I'm looking for something around 4000k to 5000k, at least 95 CRI, with no flicker and a smooth spectrum. (By smooth I mean no harsh blue spike in the spectrum coverage).
Any ideas? I'm thinking either a strip or a fixture that I can hang above it.
jross20
Georgia, USA
Dave_H
Ottawa Ont. Canada
Interesting topic. I see a proliferation or LED linear T8 tube and non-replaceable fixtures available, some at low
prices. I presume you mean ac line powered. Here's a rundown of what I know.
(1) Linear LED tubes in regular balasted fixtures have hit-and-miss compatibility, by first-hand experience.
Reliable operation with direct-wire (self-balasted) T8 tubes with correct fixture. "Hybrid" tubes are available but
seems to be a small efficacy hit and slightly higher cost than non-balasted.
(2) Increasing number of strips/fixtures are designed with LEDs which cannot be replaced. Personally I am avoiding this
trend as even if the operating lifetime is to be believed, the whole fixture is tossed at the end. Keep in mind that
common measure of end-of-life for LEDs, unless something outright fails, is decrease in brightness to 70%.
Another issue is if you want to change the brightness/tint later, can't do without replacing the whole
fixture. With replaceable tubes, at least there are options.
(3) With LED T8 tubes, if you go that way, expect 100-120 lumens/watt typically. Old fluorescents
were not all that bad compared to incandescent; typically 75 lumens/watt.
(4) Can't say what CRI is for most regular retail T8 LED or fixture lights as they typically don't give it
up-front in specs or on the tubes; but I think 95+ is dreaming a bit unless you buy specialty,
which will cost more.
(5) 2700-3000K and 5000K for LEDs appear common, less so 4000K. Also, can't comment on
blue peak.
On my workbench and electronics bench I use individual 5000K bulbs with reflector, or small
spots, which can be pointed to concentrate light. Some combo of fixed with pointable might work
for some. These days 100W equivalent LED is only 12-14W.
(6) How much light do you need (lumens) or is that TBD? Some LED tubes have lower output than
legacy T8 fluorescent e.g. 2100 lumens (17-19W) v. 2400 (32W), though better efficacy.
Dave
jross20
Georgia, USA
blue peak.
Dave
Howdy!
So far most T8's I've seen are only 80 CRI or lower, but even the 90 CRI units that I can find have a huge spike in the blue spectrum. I've slowly started to find a few "full spectrum" LED's recently. Mostly the YUJI ones someone mentioned above. For the temp, I've just come to realize that 4,000k to me is pretty much the perfect temp. A good neutral white.
I'm not totally sure on the lumen count, I presume it would need to be at least 500-1200 I guess. I'm thinking I will learn real fast once I start building the bench. Still waiting on it to arrive sadly. Also have my hakko soldering station in route as well! Pretty excited to start really getting into soldering and modding more.
