UltraTac K18 Review and Test
Mr Baz
Like the design on this side switch and lockout function. Also dropped it more than a few times survives nicely!
I did a run time test and the Li-ion lasted just under 20 minutes it drops pretty quickly and dies after 30 mins roughly. Ni-MH high capacity cell lasted quite well 1h15m then drops down dies completely after 2 hours just under.
Output isn't quite as high using Ni-MH as the Worm 4.0 (you can see the difference hence shorter run times) still quite bright enough for a pocket light though.
Only design point to note can't tail/base stand it I would change that. If you didn't like the worm ie style/switch design this might be an alternative.
kreisl
The 2017 edition can tailstand afaik.
