I've seen quite a few posts of ZL owners saying they use a flashlight for throw in parallel to the ZL because it is such a floody light. I am really hoping that the H51 has some throw to it, otherwise it really is a niche headlamp.
For up close use you need a floody beam, and up close, hand free use is the primary reason for using a headlamp. If you need throw, a flashlight is better than a headlamp. Sure a headlamp can be made for throw, but you would be looking at something huge like the Fenix HP10.
I have high hope for the H51 too. It has a reflector so it will have some throw. If the XP-G emitter is used, the hot spot should be huge, making it possible to use it for close up work. I say this because I used my Maratac AAA light for close up work and found it acceptable. The only question is: will it be small enough for pocket EDC?
