If you want to run it on rechargeable 3v batteries then check out the Keeppower ones below.I have decided to keep the A2 original.
Nothing not reversible. Out of mine one has a Lumens Factory led main bulb. And one has an Onion Ring with Amber LED's easily swapped back. I have a Tad's bi-pin adapter but haven't experimented much so farI have decided to keep the A2 original.
There's absolutely no need to use the 3 volt rechargeables in this light. But if you have them, they will work as well as the normal 3.7 volt.If you want to run it on rechargeable 3v batteries then check out the Keeppower ones below.
KeepPower RCR123 1000mAh 2A
Has anyone gotten these to fit? They don't fit in mine. Too wideThere's absolutely no need to use the 3 volt rechargeables in this light. But if you have them, they will work as well as the normal 3.7 volt.
They were keeppower. I don't remember the exact model, but they were the 3 V RCR's. I gifted them to someone else, so I don't have them anymore. I use LFP cells instead
Don't the tailcap resistors vary by model? Do you ever encounter differences in low modes?View attachment 56346And for anybody who worries about ano mismatch, one viable solution is just to buy a bunch of 'em & swap around the parts until everything matches.
SF A2, L1 (gens 1 thru 6), L2; all had 10ohm tailcap resistors. Not sure about the more modern A2LED and LX2 (non-knurled tailcap), which I don't have.Don't the tailcap resistors vary by model? Do you ever encounter differences in low modes?
I have the 2 cell drop in. It is one of the older 300 lumen ones. It may not be as bright as other lights, but it does run for approximately 3 hours on a fresh set of cr123 batteries.Do you have the drop-in for one or two cells? Are there any other led options for the E2E.
300 lumen is quite bright for most tasks.I have the 2 cell drop in. It is one of the older 300 lumen ones. It may not be as bright as other lights, but it does run for approximately 3 hours on a fresh set of cr123 batteries.
I'm surprised it would even light up with one 3.7V battery. The bulb/buck circuit is 4.2V.I never had 16650's that would fit. Was using AW 14670's back in the day
Now I'm curious. I do have a 16650, but I'll bet it's too fat to fit in the
