They are made in China. There is someone who did a discharge test on them on youtube:
Had to join to comment. I have a made in china tester that requires 1 18650 to power it and 1 18650 to discharge it. Have had fairly good luck with it. Running 3.9 volt on it it's around 1748 right now . Brother got 3 4 packs so thats a bit to test. They required some charging as they come out 3.8 to 3.9 volts out of the pack.. $3 probably at Walmart on July 30 2021. Different wrapper. I think I got some gray laptop batteries to get to 3000 mah. But that is a rarity. They came out of a recalled battery pack for a Dell Lat 620 I believe.. (not the widescreen Dell Lat 820 gray wrapper. The greens were the best but I've had those while so not much luck on those. And these are not flat so I can run them in most headlamps. Without getting a magnet for it. (ones I've found are very tiny, don't know why. they coulda been a bit larger so nobody swallows those or tried. They could of course but the ones I have ar about the size of a gnat. This is the specific tester off banggod. Didn't really understand how it worked until I messed with it. It's all in Chinese. has options for mah, mwh, and volts and to + or - the volts there is a switch for on. I think start is the left of the 4 buttons. The white cap will get rather hot (now at 1805 mah with a 200mah rating so we'll see. The start button will stay steady till it cuts off sometimes around 3.6 volts. Not sure how good the tester is but again it's been fairly accurate on the cheapo's. Revenants got 2. Claims 5000 and they don't make many above 2000. So it tests out 1 cell now 277 and the second around 1300. The bad one was originally 601mah. Actually the last test was 200 mah but, I shut it off for a minute and got 77 mah more out of it. But keeps cutting out.. (end test of 1 cell 2056 mah) These have 2020 dates on them.
XH-M240 Battery Capacity Tester mAh mWh for 18650 Lithium Battery Digital Measurement Lithium Battery Power Detector Tester Voltmeter
