ghostrider
- Joined
- Nov 12, 2005
- Messages
- 214
Hello all.
I don't get on much anymore and with limited internet access it's even more difficult.
I'm hoping you can help me select a new flashlight for walking home from work at night.
I like the 6P form factor, and currently use mine with a A19 extender and the P91 LA.
What I want is something with a dual mode momentary tailcap that uses a LED (Something that works like the L1 did with partially press in for low, and all the way in for high).
I wanted to use my current 6P w/extender, but it doesn't sound like thats doable. Things I like about the 9P/6P are that I can utilize the SF lanyard ring at the tail cap, and the crenulated bezel that I bought from it from Lighthound. I use the lanyard ring and the bezel as a retainer for the lanyard that I use to hold it to my belt, so it would be nice to be able to continue using those. I also like the size.
This light will be used for mainly lighting my way home (low setting), but also want the momentary high setting in case of emergency. I'm on a tight budget, so I don't want to spend any more than I have to. However, I also understand that good lights do cost money.
I appreciate any help you can provide in recomending a light or pointing me in the right dirrection as I don't get a lot of time to surf the web.
Thanks in advance.
Thanks in advance.
