swordfish2
- Joined
- Nov 3, 2008
- Messages
- 42
You can't. They measure two different things.
ok, but we cannot even compare these? something like
100 lumens is greater than 100 candles? anything like that?
Ok, how can we convert lumens to candles ? seriously i don know this.
Hey guys,
I found a conversion that said 1 lumen = 0.0003Watts. Surely this is wrong?
You can buy a 3Watt flashlight, which has an output of 65L, so is there anyway to compare the 2 values?
Stuart
That may be correct at some specific color, but:
Lumen is defined according to the eyes sensitivity, i.e. the watt<->lumen conversion is depend on the color of the light. One extreme is UV/IR light, your can have lots of watts in it, but the lumens are 0, because we can not see it.
And with flashlights (and anything else), your can not expect a 100% conversion, a lot of energy is wasted in heat.
Some typical values are:
incan: 5-30 lumen/watt
led: 60-100 lumen/watt
incan will have improved efficiency when really hot, i.e. very white light.
led will best efficiency at low output.
