jch79
**Do Not Feed The Vegan**,
FWIW, my Mule has a beefy bottom...
The only problem is that it, just like all the other Ti-Heads, won't be able to turn on high mode on the III-T body. That would have been a killer combo !!
bernie
Codeman,
Thanks for the link and yes, the wide bottom moniker is missleading, we should crisen it wide bezel.
My Mule head would not work on my C pak from my XR19-C.
Tim
:thinking: :shrug: Humm.... I don't know what is going on here. I cleverly don't even have a single C pak so I can't even check this out!
Rudi,
If I made that statement then I made it in error; either I wasn't thinking or misread the question. Sorry! The original Ti twisty paks have the "contact shoulder" just a tiny bit too deep for the contact ring to make contact with. You will find the head bottoms out on the pack prior to getting into "high". A modification of adding some solder lumps on the contact ring or a male/ female shim that went between the converter and the head to elevate the converter and contact ring could be employed as a fix.
On one hand we now have some folks interested in the C pak because of is extended length over the PD pak and on the other hand some like the slightly shorter and simple twisty pak for the Mule. :shrug:
awtyd,
You can't just drop a bomb like that and not explain to us newbies. Please, what is a wide tail? :thinking:
Thanks, Ken
Here's another shot I just took:
Original Ti PD on the left (my main EDC), Ti PD-S in the middle, Ti PD Mule on the right. Note the chamfer angle on PD-S and the Mule. It's less angle, hence more "beef" along the edge. That's what I meant by a "wide tail."
Hi guys,
The first wave is now all gone and spoken for. There will be at least one more wave of these but I don't know when yet and I will be very curious as to what those of you who caught one, think of it!?! :thinking:
Thanks and sorry for those of you who missed it this time.
