Sold/Expired WTS: Downsizing my light stuff...
Greenbean
WNC
I need to move some older lights along to some new owners, all are NOT new or scratch-free! Lol...
PayPal G&S please. Shipping is on me, via USPS Priority Mail with Tracking. U.S. Only
Please post "I'll take it" and send me a PM and I'll get you my payment info.
_______________________________________________________________
SOLD for 60
First is this mag build from fellow CPF'r Kid9P three years ago this March, Its been a fun light to keep on the top of the fridge for backyard blinding sessions!
This thing will light up a huge field with it's 6 XML2 led's @ 2,800 lumens.
Comes with the two 26650 cells seen,
The UI consists of 4 groups.
1. Ramp mode low to high with memory.
2. Low 2%, Med 25%, High 100% with memory.
3. High 100%, Med 25%, Low 2%, Srobe, SOS, Beacon, NO memory.
4. High 100%, Low 15%.
Mode groups are switched by 8 fast clicks
SOLD for 85
Second is this FM 26650 body I just got in and I decided to add a LF E to C adapter and
a Z44 with an aggressive bezel ring. Light comes with the 26650 and the 3.7V P60 style lamp.
Great little light in there hand and who knows how long it will power that 3.7V lamp due to the
amazing capacity.
SOLD for 90
Third is another 2D Ma$, this one is a 2D (2x26650) XHP-70 M2 3500K
Emitter: XHP-70 (warm white). This is a forward clicky light that gives you the ability to use momentary on using the side switch. This light was modified by Matt of Adventure Sport Flashlights (vestureofblood here on CPF) - This light puts out anywhere from an approximate lumen on low to about 4000 lumens on max. Being a maglite and having the ability to focus, keep in mind that against a white wall a donut can be observed in the hotspot. This is a result of the 4-die cross XHP-70 emitter. In actual use outdoors this is not noticeable. Uses and includes 2x26650 batteries. Matt machined an aluminum spacer and affixed it inside the tube to prevent rattle with the 26650 batteries. The tube can be removed and is a nice piece I might add. The spring was also shortened by Matt to more easily accommodate the batteries. The programming can be changed using guppydrv rev1 driver software instructions.
This firmware allows the ultimate in user customizability, with up to 24 built-in mode groups, that the user can select via a series of button presses and a user programmable turbo timer that will automatically step the power down to 50% after the set time is hit (see below for instructions).
Low voltage protection: 2S+/zener mod Drivers will begin stepping down at approximately 6V under load.
The light will not shut completely off, but will continue to run at a moonlight level.
To switch mode groups: rapidly tap the switch 8 times, the light will then enter the programming mode and begin to flash.
With the light in programming mode, tap the switch the same number of times as your desired mode group.
The light will blink and your mode group will be memorized
Rev.1 User Selectable Groups:
1-1% - 25% - 100% | Memory
2-1% - 25% - 100% | No Memory
3-100% - 25% - 1% | No Memory
4-1% - 25% - 100% - Strobe | No Memory
5-1% - 25% - 100% - Strobe | Memory
6-10% - 100% | Memory
7-10% - 100% | No Memory
8-100% - 10% | No Memory
9-100%
10-100% - Strobe | No Memory
11-Strobe - 100% | No Memory
12-ML - 2% - 25% - 100% | Memory
13-ML - 2% - 25% - 100% - Strobe - Beacon | No Memory
14-ML - 100% | No Memory
15-100% - ML | No Memory
16-ML - 100% | Memory
17-ML - 1% - 5% - 15% - 40% - 100% | Memory
18-ML - 1% - 5% - 15% - 40% - 100% | No Memory
19-100% - 40% - 15% - 5% - 1% - ML | No Memory
20-100% - 40% - 15% - 5% - 1% - ML | Memory
21-1% - 5% - 15% - 40% - 100% | Memory
22-1% - 5% - 15% - 40% - 100% | No Memory
23-100% - 40% - 15% - 5% - 1% | No Memory
24-100% - 40% - 15% - 5% - 1% | Memory
The light is in great shape considering its age, I have never taken it anywhere but kept it around for evenings outside by the fire pit and backyard fun.
Greenbean
WNC
Re: WTS: Custom Vestureofblood 6 x XML2 Mag Build
Price drop,
Greenbean
WNC
Price drop
Greenbean
WNC
Yes sir, includes two of them.
My apologies the picture wasn't clear and I thought I had that in the text but I'll add it. [emoji106]
Greenbean
WNC
All your bro!
PM sent!
Thanks
Greenbean
WNC
Added a nice black "Tactical Cucumber!"
Kid9P
NJ
OMG I forgot about that Mag!!
Also, I'll take the cucumber setup!
PayPal sent! Thanks
Greenbean
WNC
Added another 2D!
Kid9P
NJ
Someone's going to get a sweet deal on that Mag !
Greenbean
WNC
Bump with a drop!
