WTS Surefire E2L
michaex
how can you tell that with the limited info given by the seller?
desert.snake shared that it pulls 30/300 mA - so it's a dual stage head. There were only two dual stage E2L's so far - and only 3/60 with this shape of head. Simple ;)
AstroTurf
RVA USA
mine, sitting right in front of me has the same head model designation, and it is only a single output model.
thermal guy
ny
The old "first " KX2's were single level. 45 lumens I believe. Then upgraded to the 3/60. That's what this should be.
desert.snake
Eastern Europe
Wow, so much information, thank you!
There is another way, if someone has a luxometer and the same lights and some kind of known E2L, then you can look at the numbers. This board has a length of 97 cm, I accordingly put the lanterns 6 cm further, because luxometer is about 3 cm thick. Daylight from the window constantly adds about 36-40 lux due to the movement of tree branches from the wind.
