Tachead
No problem[emoji106]. Let us know how it is when it arrives. I have the H600Fc MKIII and love it.I will be ordering the H600fc . Thank you for your good advice. [emoji106]
Hard to say. It isn't even slated to start shipping until Dec. 15 so probably not for a while. It will likely be better then the MKIII's though and they are already great so I wouldn't worry.When will ZL have the run times of the new MK IV posted?
I have a question for Zebralight experts. The sc600 mk3 and mk4 appear to be using the same LED. Does that mean they are just driving the LED harder to push out more lumens? Where is the compromise?
Looking forward to see how the runtimes compare once announced.ZL is using some newer components and has increased the efficiency of the driver with the MKIV series. That is likely responsible for most of the increase in brightness but, I am not sure if they also boosted the current a bit. If they did it is still within Cree's specs for the emitter. ZL does not overdrive any of their emitters.
Do any of you gentlemen know of a pocket clip that works great on the H600?
The Nitecore MH20 clip fits perfectly. You can get one here(it is option B)...
http://www.nitecorestore.com/Pocket-Clip-for-Nitecore-P12-Flashlight-p/acc-clip-nitecore.htm
ArmyTek Wizard Pro - you can buy them individually here: https://ru.nkon.nl
Here's what it looks like: https://goo.gl/images/DWvakz
I'm waiting for two in the mail.
The MH20 clip I linked fits much better imo. Aside from being black, it is like it was made for the H600 series. The Armytek clips I tried were slightly too wide for the grove in the H600.I own a Armytek Wizard Pro. I will steal it off of it when I get the H600. Thanks guys!
They don't fit very well to be honest. They are too wide to fit in the channel on the H600 and will need to be filed down a fair amount to fit right. The Nitecore MH20 clip I linked above fits perfectly, without modification, like it was made for the H600 series.ArmyTek Wizard Pro - you can buy them individually here: https://ru.nkon.nl
OK thanks. I am looking for a perfect fit. So this is good to know!
