Sorry for the barrage of questions but I am a newbie to lights and a newly discovered flashaholic
I've tried putting rechargeable CR123s in my G&P M3 weaponlight (which uses the same voltage xenon lamp as a Surefire 6P) and turned it on -- instantly blowing up my bulb.
This is the first time I've ever used rechargeable 123s and learned my lesson in hindsight.. rechargeable L-ion 123s hot off the charger have much more voltage than 3V each..
The batteries and charger I used were from here - http://tinyurl.com/2v9rb2 - has anyone ever seen/used them before?
I could have sworn I saw somewhere that these cells (green, says L-ion, 1000mah and 3V on it) were protected-circuit.
I am going to buy a Surefire 6P Defender and want to use rechargeable 123s in it (but of course do not want to instaflash ever again!). I was looking at some drop-in CREE bulbs - would this work - http://tinyurl.com/38ow9m ?
It could raise the lumens from 65 to 200 and according to the description, quite tolerant of varying voltages (4.5V to 9V). I should be safe even with freshly charged CR123s right?
thanks so much, everyone!!!
