Tana
I'll try to post few options for each model to give an idea of what can be expected in performance and price range.
Surefire LX2:
1. LX2 "Ultra", XPG2/219B/XPE2, 1.4Amp, Single Mode, OP reflector, GITD around LED, body bored for 16650/17650, tailcap modified for desired/proper low... $124
1a. LX2 "Ultra" CLICKY, XPG2/219B/XPE2, 1.4Amp, LuciDrvFT multimode firmware, OP reflector, GITD around LED, body bored for 16650/17650, tailcap modified with McClicky... $150
2. LX2 "UltraS", XPL-HD/HI/219C, 2.6Amp, Single Mode, OP reflector, GITD around LED, body bored for 16650/17650, tailcap modified for desired/proper low... $136
(this is "hot-rod" setup, head will heat up after 1-2 minutes of use on high, high not to be used for prolonged periods of time)
2a. LX2 "UltraS" CLICKY, XPL-HD/HI/219C, 2.6Amp, LuciDrvFT multimode firmware, OP reflector, GITD around LED, body bored for 16650/17650, tailcap modified with McClicky... $162
3. LX2 "TripLED TACTICAL", triple XPG2/219B/XPE2, 3Amp, Single Mode, GITD around optics, body bored for 16650/17650, tailcap modified for desired/proper low (upgrade to triple XPL HI possible, extra $20)... $202
3a. LX2 "TripLED CLICKY", triple XPG2/219B/XPE2, 3Amp, LuciDrvFT multimode firmware, GITD around optics, body bored for 16650/17650, tailcap modified with McClicky, (upgrade to triple XPL HI possible, extra $20)... $228
("hot-rod" setup, head will heat up after 1-2 minutes of use on high, high not to be used for prolonged periods of time)
Surefire A2:
A2 Quad pricing:
$168 A2 Quad Base price (XPG2, 3Amp, fixed modes)
$30 Upgrade LEDs to premium XPL HI (4ea LEDs with matched Vf)
$22 Upgrade to H17F driver (linear/FET hybrid)
$40 Boring ROUND A2 body for 18650 cells
$26 HACS switch for when FET driver is used (setups with up to 4.5Amp and linear drivers will use McClicky, same price)
$30 Hand machined low profile Brass Shroud to match size of the custom boot used with HACS/McClicky upgrade
$15 Optional 24mm big GITD disc (GITD tape cut to size, layer of epoxy/powder applied for even more glow)
A2 TripLED setups are also possible, most of the prices are same as Quad with difference in LED upgrade (or complete base upgrade depending on what LE/driver is used... PM for details)...
Surefire L2:
PM/email for details, mod is operational...
Surefire L1 Gen 1, 2 and 3 (square body, small hex head):
Surefire L1 Gen 4 (square body, KL1-lookalike head, domed lens):
Working on details... no complete overhaul, body can be lego'd with e-series head of moddable choice (incan, KX2, KL4, etc)
Surefire L1 Gen 5 (round long body, KL1-lookalike head, domed lens):
Surefire L1 Gen 6 (round short body, KX1-lookalike head, flat lens):
TripLED or Reflector/Extreme, TACTICAL or CLICKY... PM/email for details, mod is operational...
Surefire LX2:
Surefire A2:
A2 Quad pricing:
Surefire L2:
