Does keeppower battery fit Nitecore HC90?
elcidroyale
I am getting a HC90 & need a battery. I have decided on keeppower. I know that different brands fit better than others. Will their 3400 or 3500mah fit?
I've noticed some 18650 batteries go a lot higher then 3500mah. Would those fit? Can I go larger capacity than 3400 mah for this headlamp?
allangalbraith
I have some Thrunite 3400 Mah batteries that I use in my HC90 from time to time. The thrunite is 18.5mm x 68.6mm. and it fits in my HC90 but its tight. The Keeppwer 3500 Mah is 18.6mm x 86.9mm. So it's just barely larger than my thrunite battery which fits but again it's tight. I would not recommend anything larger than that. Remember this thing is attached to your forehead, don't want any mishaps :)
PaladinNO
Norway
Ah, I see I got here just a little too late.
I too got the HC90 (outstanding light! Pricey, but worth it), and I got some Keeppower 3500 mAh's. As you already found out, yes it fits.
The Orbtronic 3400 mAh is what I use in it normally. The Keeppower 18650 is slightly longer - by about 0.7 mm, I'd say, without taking it to a digital caliper.
