Charging NiMh with a C9000, what charge rate to use?
RegularGuy81
Ohio
Just curious what charge rate do you use when charging your NiMh (Eneloops)? The manufactures guide says not lower then .3C and not higher than 1.0C.
Typically I half the rated capacity… eg: If I am charging a 2000mAh cell, I set the charge rate to 1000…. I guess that would technically be .5C?
Since we are discussing the C9000, do you use any of the other modes; Refresh, Cycle, Break In, and when?
Burgess
USA
For AA size, I use 1000mA rate
For AAA size, I use 500mA rate
louie
Seattle
I do the same as Burgess et al. For AA Eneloops, it's easy since the C9000 defaults to 1A (.5C), and this hits all the criteria nicely - higher than .3C, lower than 1C, batteries don't get too warm, terminate reliably, etc. I'm never in so much of a hurry that I feel the need to up the charge rate. Also, I am not so fastidious that I use the refresh, cycle, break in functions much, unless I have cell that is definitely acting up. These functions just take too long for me, hogging the charger.
