xochi said:
Hey Greg, will this be one of the 'pic' type boards with LDO/PWM regulation? If so , does that mean that even though there are 3 twists to 'High' (<.8 sec between each twist) one more twist (after >.8 sec) gets you to 'Off'?
Also, please make the emitter end user swappable:naughty:. Not much point to a light that will last 300 years if it seems obsolete in 3. Sorry if this was already mentioned, the TLTL syndrome is acting up (Too Lazy To Look).
Hi xochi, yes, you got it right regarding the board. It is an LDO/PWM regulated board. However, the interface on my custom board has been simplified from the standard interfaces offered by the POP2 or the FluPIC.
For each On/Off less than 0.8 seconds, this one goes from Low, Middle, High, then Low, Middle and High again, then on the 7th twist, it will be for user setting of the middle level. After that, it resets and goes back to the first twist and comes on at Low again. Also, anytime that you leave the light on for more than 0.8 seconds, the interface will have reset and goes back to the first twist on the next turn on, coming on at Low. Very simple..
The emitter should be user swappable. You will just need to unsolder two points, and the emitter can then be taken off without any problems.. I'll be using Artic Alumina for good thermal contact between the emitter to the board.
