thedoc007
Neither one is going to blow you away...they are small, practical lights, not lumen monsters. The Klarus is tougher, but only has one mode, and it isn't particularly bright. It is a somewhat focused beam, where the Tube is all flood (no reflector or optic at all). The Tube is plastic, rather than metal, but since it weighs almost nothing, it is still reasonably tough...you are VERY unlikely to damage it simply by dropping it. I wouldn't put it through the dishwasher, though. (Well, I already did [for science!], and the results were not good.) The Tube is easier to take apart, if you want to see more than just the outside of the light...all you need is a screwdriver. The on-board battery could be either an advantage or a disadvantage, depending entirely on your preference, and availability of a spare micro-USB cable.
Choice is up to you. They are very different lights, so it is not possible to say one is empirically better than the other.
