Schokokeks
See my post #3006 in this thread for my argument of "reading between the lines" that they're planning an an AA engine.Where did you hear there is going to be a single AA light?
I have read that the new light is going to use an 18500 body tube. (which would work with single 14500 LiIon, but not single AA primary)
I couldn't have said it better myself.A durable and dependable light like the HDS I think would need AA support. If I'm depending on a light to work each and every time I need it, I would like AA support or at least a tube option for it. CR123's are getting ridiculously expensive meanwhile there's always a AA battery around, or any store carries them, and they are cheap. Not to mention rechargeable eneloops. 18500 is nice and all but there's not really much buying options for 18500s, plus makes the light wider and heavier. IMO a AA/14500 is one of the best battery options in a flashlight. Standard size and tube diameter would be a bit thinner making less bulk and thickness while carrying.
The current HDS offerings, frankly, are harangued by the limitations of the CR123A battery. You could maintain the similar levels of performance of the current line of HDS (or maybe 75% of that) with a single AA eneloop format, 14500 Li-ion if they're feeling spicy.
Plus, if you ask me, if you're going to try and make an apocalypse proof light, it needs to use eneloops. Single use lithium cells like the CR123A, as noted, are becoming more niche, and are expensive. AA cells are the most ubiquitous cell there is. There have to be tens, if not hundreds of billions of AA cells on the planet. People seem to forget that AA/AAA cells already won the "size wars." They are just a perfect sweet spot of size and capacity. Yes, you can get bigger cells, but AA and AAA just make for perfect handheld items. The AA cell size is from 1907. It's going to be around in 2107. Will these other cell sizes? Remember how 18650 was the new standard? It's what, 20 years later, and now 21700 is the new standard. But, I'm sure people will grow tired of their giant lights, and that might change, again.
AA cells remind of 9x19 pistol cartridges. They're about the same age, and they are both the standard, but both have gone through periods (recently, too) of having their noses bloodied by enthusiasts (or, snobs, alternatively), pushing more min/max specialized options...yet, they persist, and just won't die. They get updated and modernized with the newfangled gee whiz chemistries and features, and then just keep dunking on the competition (see: modern 9x19 rounds and 14500 Li-ion and Eneloops).
I'm actually a proponent of the idea of not overdriving an LED, but in 2024, 175-325 maximum lumen lights just don't make a lot of sense - unless we're talking about an AA light. That's an absolute perfect fit for the cells, and you're going to get similar runtimes from an eneloop to a CR123A at those outputs.
18500 is very cool, but that's rapidly disappearing. 18350 and 16340 have more options, for now, but 14500/AA has already proven itself, and has similar capacities.
And I'd agree on the thickness. As time goes by, I realize length doesn't make a light as awkward as width in most cases. 14500/AA cells can be a LOT thinner than 18500. Maybe that's cause I have kind of big hands...but I think this is just actually true in general.
