Thetasigma
Done.Thetasigma, I'd like to change mine from 18650 to 18500. TKS!
Done.Thetasigma,, I'd like to change mine from 18650 to 18500...thanks sir
Done. If you get tired of waiting you could always try to pry Dell's from him...:DCare to add a second light for me to the bottom of the list? Al-Bronze 18500 knurled w/clip please.
Hell NO!!! [emoji13]Done. If you get tired of waiting you could always try to pry Dell's from him...:D
On a side note: 18500 tube is really a good balance of size & capacity. It does feel a little heavier in the pocket but I'm sure most of you will have no qualms with that.
Please change me to Aluminum Bronze, 18500. If it becomes available in 18650 I'll go for that. But the material is more important. :thanks:
Unless I've misunderstood, the interest/order list seems to be open-ended. Can I take a spot at the end of the line? 18650/brass/knurled/tapped for clip screws/narrow clear optic/sapphire/green o-rings/glow sticker. I would gladly pay a premium for a titanium version if that becomes a possibility. I'd also be interested in Al-bronze if that's ever viable in the 18650 format. Is tumbled finish still an option?
I'd go for that.Would there be any interest for Serge's 371D driver? It is the same driver/XP-L 4000k combo that is in the Overready Wasp and BOSS.
They offer extremely good efficiency in all modes (90-97% efficiency per Serge), current controlled, secondary red LED, bounce sensor, fully programmable, on board temperature regulation, and wide voltage range 1-2 cells.
I'm thinking of offering these as an option in addition to the standard H17F. They are very expensive though, so additional cost would be +$50 for that setup.
