Tachead
^done^
Last comment regarding the Tactician:
I bought a second E1B-MV and tried the Tactician head on it, and it works -- with two different Tactician heads! So apparently in addition to the "tint lottery" and the "anodizing lottery", Surefire lights also participate in the "threading length lottery". The difference in the length of the threaded section must be miniscule from one body to the next, but sometimes a miniscule difference is just enough to make something work or not work. So anyway, now I have an E1B MaxVision with the two modes selected by adjusting the head of the light, rather than by blinking the switch. This is how the E1B-MV ought to be configured.
Sorry to keep bringing up battery stuff and this light but I went and bought quite a few different 16340s to test out trying to find a rechargeable battery for this light. I’ve tried 5 different protected cells and even an efest unprotected and they won’t power the light on in high. Grr this is frustrating. I guess I’m stuck with using primaries only.
I am guessing your protected cells can't handle the current draw on high(over discharge protection tripping) or are old stock/worn out. My EDCL1-T runs just fine on both my Tenergy LiFeP04's and unprotected Efest 16340 V1 flat tops. Several others in this thread are running their lights on rechargeables too without issue. Maybe you could try a brand new unprotected high discharge cell from a reputable dealer(I recommend Illumn)just to be sure. Hope you get it sorted man.
So question!! Does anyone know if the EDCL-1 gas pedal tail cap will work on the newer Aviators or the EB1?
Yes I have oft considered it but 200 lumens? Ugh
I have the EB1 and I said the same thing, until I used it. The 200 lumens throws farther than any Fenix or Olight I own. It's extremely throwy. So much so that it's almost too focused for EDC tasks.
The EDCL-1T? I find that it is a bit on the floody side, which I prefer. I suppose it depends on what you are used to. But, I would never call the 1T throwy. I'd probably call it a bit floody.
Is it possible to convert this to the 2-t? Is there just a two cell body available?
