Here's an all "physical" display having just about all functions without using any electronic display...
Left Buttons are FLASH, PLAY, LOW POWER
Right Buttons are LAMP POWER, SCREEN BRIGHTNESS, KEY LOCK
Button Actions -> Functions:
Touch FLASH button
-> Intermittent flash
Hold FLASH button for 5 seconds
-> Flash remains on
Touch LOW POWER button -> Intermittent low power
Hold LOW POWER button for 5 seconds
-> Low power remains on
Hold LOW POWER button for 30 seconds
-> Set "Power Down Timeout"
NOTE: "Power Down Timeout" is the amount of inactivity time before system automatically shuts down if the lamp is off. I figured I'd create this setting in case someone wants to use the display for a night light. This setting remains until changed, whereas "Lamp Off Timer" applies only to the current lamp power cycle.
Touch focus slider
-> Go to absolute focus position where touched
Slide focus slider
-> Move focus position tracking slide movement
Hold focus slider for 10 seconds
-> Set Focus
Touch PLAY button -> Play animation
Hold PLAY button for 10 seconds -> Record animation
NOTE: Record animation will have to be a two-step process. First to record the beam spread actions. Then the beam spread actions are played back while recording the flash & dim actions.
Hold LAMP POWER button for 10 seconds
-> Set "Lamp Off Timer"
Hold LAMP POWER button for 30 seconds
-> Set "Lamp Power Button Delay"
Hold LAMP POWER button for "Lamp Power Button Delay"
-> Turn lamp on/off
NOTE: "Lamp Power Button Delay" is a configurable setting to determine the amount of time required to hold the power button to turn lamp on/off. Delay can be set up to 5 seconds.
Touch BRIGHTNESS
-> Cycle display brightness level
Hold BRIGHTNESS BUTTON for 30 seconds
-> Reset lamp hours
Hold KEY LOCK button for 3 seconds
-> Buttons locked, except beam adjust
Hold KEY LOCK button for 10 seconds
-> System Lockout
Hold KEY LOCK button for 30 seconds
-> Reset password
NOTE: Key Lock can be enabled even when lamp is on, although beam focus will still function. The purpose of enabling key lock even when lamp is on is to prevent inadvertent button presses in adverse use conditions.
NOTE: System Lockout requires password entry for any new actions. Can be enabled even when lamp is on. Not even beam focus will function. Prevents use by other people while system is on.
Security:
-All actions require password entry, just once per power cycle, unless no password is set.
Illuminated Keypad Mode:
-In center of slider is a keypad which only illuminates during functions "Reset Password", "Set Lamp Off Timer", "Lamp Power Button Delay", and "Set Power Down Timeout", or any time when prompted for password. Other buttons are dimmed during keypad entry. No room for "zero" on the keypad. Zero is more important than 9, so zero replaces 9 on the keypad...
What's nice about this display is there is no worry of the electronic display going bad, especially after it's gone out of production. I could still include a serial connection port for connecting with a separate touch screen to access system stats and remote control. So far, this one is my favorite. Physical buttons are always better than images of buttons on a screen and this display makes full use of that.
Keypad Mode:
EDIT -
Printable PDF
Updated the additional functions.
For anyone still craving a display with meters etc, I could make the serial port also have a mount for a detachable display. Cool things coming out, a
Transparent OLED would be nice.
